It is currently Fri Nov 27, 2026 5:11 pm
 Post subject: .50 over pistons?
PostPosted: Fri Dec 14, 2012 4:45 pm
PostPosted: Fri Dec 14, 2012 5:49 pm
Site Admin
If it has metric pistons, the oversize could be .045"
CJ
PostPosted: Fri Dec 14, 2012 6:05 pm
I would guess it was .040" over and has worn. Depending on what piston clearance was set at, it may not be worn that badly.
Order .060" over pistons and call it a day.
PostPosted: Fri Dec 14, 2012 8:27 pm
PostPosted: Fri Dec 14, 2012 8:38 pm
Wow....
I've never seen 2 hours and 22 minutes between identical posts before.....
:shock:
PostPosted: Fri Dec 14, 2012 10:35 pm
Site Admin
With the current solar activity, close pass of an asteroid, and the Mayan apocolypse bearing down on us, Santa was forced to fly lower than usual in his initial test orbit to avoid destructive resonance vortices.
This caused the internet to skip. Just bump the needle on your computer, and the music will continue as before.
CJ
__________________
Glad to be of help :D
PostPosted: Fri Dec 14, 2012 10:49 pm
Frikkin' smart phone my azz. :roll:
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 1 guest
