It is currently Fri Nov 27, 2026 5:50 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
 Post subject: Re: These two...
PostPosted: Tue Dec 18, 2012 11:21 am
Is oil coming out at the head gasket, valve cover gasket, or spark plug tubes?
1975+ engine, no plug tubes if using 1975 head or his 1987 head.
These notoriously leak at the head gasket between the block and head at the lifter gallery. Easiest prevention is after installing the head and torquing the head to run a little RTV into that gap using your finger to smear it into place (Doc Dodge Slant Building Tip #76).
Wow on both counts. No plug tubes on a late Slant 6? I need to find a picture of this. EDIT: Found it. http://www.slantsix.org/articles/racing ... heads.html
I actually just removed my head to replace valve stem seals. I'll do that RTV fix. That side of my engine has always been oily.
Escape Velocity Racing
PostPosted: Tue Dec 18, 2012 11:23 am
Have you inspected the oil pressure sending unit whil running, under pressure?
I have seen a number of these units leak right out the end, where the wire terminal exits the body... the drops of oil fall clear, right onto the roadway, no leak or puddle when the engine is off and the vehicle is parked.
If not that... it's time to "run her hard"... and try to get the rings to seat.
After that... re-ring it.
PostPosted: Wed Dec 19, 2012 10:01 am
if it comes to re ring it do you think i would require another rebore after these few miles? how about the head? redo it as well ?
PostPosted: Wed Dec 19, 2012 11:52 am
Likely just a re-hone and a new set of rings but you will need to get in there and "find the problem" to know for sure.
Close inspection of the ring packs will be in order. Look to see if they were installed in the correct location, in the correct position, with the correct gap, etc.
PostPosted: Wed Dec 19, 2012 7:55 pm
I could live with 20% leakdown on a used- hi miles /6, but with less than 10K something's not right. Doc's got the correct idea- run it hard with quite a few WOT accel 40-70 & closed throttle decels.
The bore could be glazed, or ring gaps stacked, rings put in upside down, etc. Or there could be a problem with the oil rings that won't show up in compression or leakdown tests. You might not be able to tell if your engine smokes from the driver's seat- it has to be BAD before you see blue fog in the mirror (you are looking in front of you while you drive?). Have someone follow you on the highway to watch what comes out the tailpipe.
If you end up tearing it down, you should have someone (else?) double check the previous work- ie bore diameter, taper, piston clearance, etc. before re-hone & re-ring. Last thought, does the valve cover have a baffle under then PCV grommet & breather filter?
63 Valiant Wagon
225 - 4 bbl
PostPosted: Thu Dec 20, 2012 7:35 am
yes there are baffles in place
thanks to everyone for the kind advice.
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
