It is currently Tue May 26, 2026 10:08 pm
 Post subject: horn wire
PostPosted: Tue Dec 18, 2012 10:50 am
where does the wire in the hub of the steering column terminate?
PostPosted: Tue Dec 18, 2012 11:16 am
Horn relay, but it goes through several junctions before it gets there. What vehicle?
PostPosted: Tue Dec 18, 2012 1:57 pm
It's a '63 Valiant /6. Out of nowhere, The horns started going off by themselves. I'm not sure what that wire does and I don't see it on the wiring diagram.
PostPosted: Tue Dec 18, 2012 2:01 pm
Could be your horn switch has failed, or the relay has failed, but the switch itself is more likely. If the wire grounds anywhere along its length the horns will sound.
