It is currently Mon May 25, 2026 7:24 am
 Post subject: magnum 500 sizes?
PostPosted: Tue Jul 25, 2006 3:49 pm
were these rims ever available in the SBP? and were they ever available as a 14" wheel with the SBP thanks
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
 Post subject: Re: magnum 500 sizes?
PostPosted: Tue Jul 25, 2006 5:09 pm
Nope.
PostPosted: Tue Jul 25, 2006 6:14 pm
But if you change over to LBP discs in your 63-72 A Body, they look absolutely great!
PostPosted: Mon Dec 03, 2012 9:43 pm
I know this is an old thread, but are these small bolt magnum's?
PostPosted: Tue Dec 04, 2012 12:17 pm
Small bolt pattern Magnum 500 wheels still do not exist.
PostPosted: Tue Dec 04, 2012 3:44 pm
The wheels that I have in the picture above are small bolt pattern. There is a picture of the Group 44 Trans Am Dart with wheels like these.
 Post subject: small bolt Magnum rims
PostPosted: Tue Dec 04, 2012 11:09 pm
Is there a part number on the rim and is there a Chrysler Pentastar stamped near the valve stem hole.
I have never heard of a 5 on 4 bolt pattern factory Magnum rim
Fast is fine but accuracy is final. You have to learn to take your time ... in a hurry
- Wyatt Earp
PostPosted: Wed Dec 05, 2012 4:56 am
I'd bet the wheel in the pic is an aftermarket wheel. Has the looks of a GM wheel. (cant remember what those were called Rally II's maybe?)
MRO....
PostPosted: Wed Dec 05, 2012 6:49 am
There is no pentastar. I just thought they would be good on a 66 era Trans Am type car.
PostPosted: Wed Dec 05, 2012 9:45 am
They would look good on a T/A styled car.....
MRO....
PostPosted: Sat Dec 22, 2012 8:16 am
Did the Tulius group 44 dart use small bolt wheels for TA racing? I have seen pictures of it with those style wheels also. In the first season of TA I think they had to use stock wheels.
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Sat Dec 22, 2012 9:08 am
There is a 5 bolt 100 mm wheel(GM) that LOOKS just like the 500's.
It LOOKS like small bolt pattern. It don't fit. :(
PostPosted: Sat Dec 22, 2012 10:21 am
I have bolted these on a Valiant. They are 4" bolt pattern. Maybe I should convert my Barracuda back to small bolt pattern and use them.
PostPosted: Sat Dec 22, 2012 2:31 pm
Big debate between 100mm and 4'' Some say yes some say no.Like oil and oil filters..I should have said I have not tried(only read) therefore should have no opinion.
PostPosted: Sun Dec 23, 2012 12:12 pm
hmmm 100mm= 3.94"..... so its not quite 4", and on wheel I think I would like it to be right on... M2C
MRO....
