It is currently Thu Nov 26, 2026 10:42 pm
 Post subject: stromberg ww carb.
PostPosted: Sat Dec 22, 2012 12:25 pm
Car Model: 1982 D150
hi every one, I would like to start by wishing everyone a merry Christmas.
I came across a stromberg ww carb at the junk yard. It was under the drivers seat of a slant 6 van.
I plan to play with it and see if I can get it working.. (just for fun)
It has 056 main jets, and the the power valve I can make out a 68.
the #'s stamped on the out side is 237200. I think it could be a 2-372???
Does any one know what I could expect if I put it on a stock slant 6?
Are the jets on the bigger or smaller size for my 82 d150?
I would like to get good performance and as much mpg as possible.
Any info would help greatly.
Slant power!!!
At least I try...
PostPosted: Sun Dec 23, 2012 10:25 pm
i guess no one has any info on strombergs....
If anyone can tell me the jet range for this carb it would help me alot.
Slant power!!!
At least I try...
PostPosted: Tue Dec 25, 2012 1:56 pm
I have used a stromberg before. I was off a 65 Dodge van with a 318. It had good power but not so good mpg. I do know that you can't compare jet sizes between different manufatures. So while that size jet on an Autolite would be grossly over rich, lt may be close on a stromberg.
PostPosted: Tue Dec 25, 2012 1:57 pm
PostPosted: Tue Dec 25, 2012 9:37 pm
Ok kesteb, turn off ye reverb... ;) Merry Christmas... (just barely her in the middle of the country.
MRO....
Cheap, Fast, Reliable.... Pick 2...
PostPosted: Wed Dec 26, 2012 8:08 am
ok,, I guess I will have to try it and see. The jets for this carb are not cheat,,
I wanted to be somewhere around the middle of the spectrum and go from there,,
Slant power!!!
At least I try...
PostPosted: Wed Dec 26, 2012 11:13 am
I got 22mpg out of one on a trip, just like a 318 sized Holley 2bbl. Stromberg carbs do not have power valves.
I got a dissasembled one the other day. Missing some screws.
PostPosted: Wed Dec 26, 2012 7:45 pm
An android and fat fingers don't always mix well...
PostPosted: Thu Dec 27, 2012 10:03 am
the stromberg I took apart does have a power valve. That is what the stromberg parts listed it as. As I said, it was under the seat of a van with a slant 6 at the junk yard, I only suppose it was at one point used on this van. I dont know why it was removed!! I will kit it and see what happens, I only wanted to know a little more about the jets and go mid way on the size. I wanted to avoid taking it apart as much a s I could.
Slant power!!!
At least I try...
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 2 guests
