It is currently Thu Nov 26, 2026 2:17 pm
PostPosted: Sun Dec 30, 2012 6:43 pm
Howdy everybody!
I've been thinking about using these plugs, has any one here used them?
I've been using NGK 6630 plugs, but I'm told that these are a bit hotter. Opinions please, thanks!
'78 Volare 225
'67 Charger 318
PostPosted: Sun Dec 30, 2012 7:44 pm
Site Admin
Take a look at thread length on those. I think they are too long.
CJ
 Post subject: Not compatible...
PostPosted: Sun Dec 30, 2012 8:49 pm
NGK stock # 6630 is for a Tapered "Peanut Plug" UR4 which is the hottest of the the plugs useable for the 1975+ heads (UR-5 common, UR-6 is available but colder)...
The 3459 plug is the ZFR-5N plug for drool tube pre-1975 heads...this will physically fit in the head but will not seal properly and the threads will be about 3/8" into the chamber and carbon up (similar results to using a Chevy 400 TR-4 in the slant six peanut plug head- at least these have the proper tapered seat...)
On my "to-do" list was to have a peanut plug head spotfaced at the exterior plug seats to see if a ZFRN could be installed and sealed...I also have a mockup for a bushing that can be added to the ZFRN plug to give it a 'tapered' body to fit the peanut plug (need to find a machinist to run a test batch off for road trials before offering to the general public).
Sadly in the normal plug for the drool tube head you are limited to GR-4's as the hottest and GR-3's aren't available, and they don't make a ZFR-4N as the vehicle these are for doesn't need them (swirl ports, quench heads, allow better turbulence for computer controlled combustion and emissions).
Are you needing a hotter plug because they are fouling?
PostPosted: Sun Dec 30, 2012 11:13 pm
Thanks for the replies!
Yes, I would like a hotter plug because during cold weather, it tends to foul.
'78 Volare 225
'67 Charger 318
PostPosted: Mon Dec 31, 2012 3:15 pm
Running to rich? Valve adjustment?
What about a Champion in a hotter range? Or quit grandma'n it around!
 Post subject: But...
PostPosted: Mon Dec 31, 2012 5:01 pm
I have not found a Champion that will burn hotter on the test try...Although, I will have to admit that AC-Delco does have a bit mroe range...I run R-45TS which gives good color for what I do and seems to be in between the NGK UR4 and 5...I have also used R-44 and R-43TS and they are equal to or hotter than the UR-4...
I would agree that you may need to quit going to the grocery store around the corner everyday and get the thing out on the highway at 30 minutes of 65+mph....
:wink:
PostPosted: Tue Jan 01, 2013 7:20 am
I bought a '67 Cuda and the 11.4:1 511 kept fouling plugs. I pulled the AC's and dropped in Champions. End of story.
PostPosted: Thu Jan 03, 2013 6:03 pm
Thanks for the replies fellas. I will agree that I probably do need to quit "grandmaing it around". However, during warmer weather, which is most of the time around here, this is not an issue. The Weber carb I'm using could probably be fine tuned a bit.
I just installed a set of 2869 NGK platinum plugs, which were only a little bit more than the 6630 NGK plugs with my discount. We'll see.
Thanks again!
Wes
'78 Volare 225
'67 Charger 318
PostPosted: Thu Jan 03, 2013 7:10 pm
The NGK ZFR5N (3459) spark plugs will not fit in a 75+ head? I just bought 6 for my 76 Aspen per SSDan's HEI retrofit article but looking at it again, I think I might have mis-read :?
76 Dodge Aspen
225 Super Six w/ Dutra True Dual Exhaust
http://i1245.photobucket.com/albums/gg5 ... AG0095.jpg
http://www.youtube.com/user/BZuko1?feature=guide
 Post subject: Yep...
PostPosted: Thu Jan 03, 2013 7:38 pm
Correct...If for some reason in the past somebody decided to install a 1974 (pre) head with the drool tubes you are in luck, otherwise you will return them and end up using a set of UR-5's.
The 1975+ head uses 'tapered seat' plugs instead of plugs that have a broad flat sealing surface meant to be used with or without the washer.
The tapered seat is just that, the plug above the threads is cone shaped and when tightened in place creates somewhat of a seal with the cone or funnel shaped machining in the head (note that this taper is small and not a long 'funnel'...more like 1/16"...)
If you use the other plug it won't seal as well and since the tapered plug has about 3/8" of threading...the 3/4" of threading on the other plug may protrude into the chamber and 1) become a source for heat spots on the thin threads causing pre-detonation, 2) carbon up and may not be able to be removed easily, 3) more the electrode further into the chamber causing other ignition effects for better/or worse, 4) put the end of the plug in to the chamber and may contact the piston at TDC if the engine has been milled or modified without measurements...( seen that before...definately we can't use the tapered seat plugs from a new corvette with the 1" of threads past the taper..luckily it was a mockup block and stock old pistons).
 Post subject: Re: Yep...
PostPosted: Fri Jan 04, 2013 7:28 pm
Oh well, returning them is easy and returns that $30 to my pocket. I'll just stick to my Champion Coppers.
Thanks for the information before I tried to force those shiny NGK's into my engine :lol:
-Aspen76
76 Dodge Aspen
Users browsing this forum: Ahrefs [Bot], valiant64 and 11 guests
