It is currently Wed Nov 25, 2026 8:00 pm
PostPosted: Mon Dec 31, 2012 3:45 pm
I am installing the heat riser counter balance, stop and spring that was missing from my car when I bought it. The damper seems to have more travel than the stop spring will alllow. The question is when installing the counter balance, what position should the damper be in. Should I close the damper and install the CB in the closed position or should I open the damper and install the CB in the open position? Or something in between? I would think the damper should be full open when hot and if it doesn't close all the way - that's OK. The other way it wouldn't open all the way when hot and that will restrict flow. Thoughts?
'72 Scamp 225 - 4 bbl
PostPosted: Wed Jan 09, 2013 8:43 am
My suspicions have been confirmed. I have installed the counter balance when the riser is hot with the damper all the way open. I have no restriction on the exhaust when it is hot. I think the damper could close more and force more exhaust up to the intake plenum when cold but with the counter balance set up as stated above it only forces some air up and over. It seems to be working great with current temps in the mid 40s and that is about as cold as it gets here.
'64 Valiant Conv V8
'72 Scamp /6 4bbl
'79 Adventurer SE
