It is currently Thu Nov 26, 2026 12:11 am
 Post subject: Exhaust system
PostPosted: Wed Jan 02, 2013 6:52 pm
Hey guys. While changing the leaf springs on my 80 d150 I noticed that the stock muffler has rotted a nice big hole through it at some point so I'm in the market for a whole new system, I think.
I've heard our slants benefit greatly from larger diameter pipes but I don't recall what size.
I am upgrading to a super six set up and I'll likely do the exhaust around the same time.
So my question is, what's a good route to go for a 1980 dodge d150 with a super six? I'd like a nice deep sound at idle with a bit of a throaty sound but it really doesn't need to be loud at all. I get enough road noise in that old truck, I don't need exhaust noise on top of that.
Thanks for any and all info fellas!
PostPosted: Wed Jan 02, 2013 7:35 pm
I put 2 1/4" pipes off the stock manifold to a flowmaster 40 series muffler, and then 2" pipes out the back. Ordered the muffler off ebay and had a shop bend the pipes and install it. Love the sound.
69 Plymouth Valiant
PostPosted: Wed Jan 02, 2013 9:29 pm
Yeah, I'm thinking 2 1/4 to a flowmaster HP2 then 2 1/2 to a flowmaster 40 or 50 then 2 1/2 straight to the back.
Not sure if I should go for the 40 or the 50...I don't want to be too loud which pushes me to the 50, but Im worried it might be too quiet.
PostPosted: Thu Jan 03, 2013 4:08 am
Loud is one thing, the 2400 to 2700 rpm drone is another which aftermarket exhaust brings to the table. HP-2 kills the drone, along with the nasty straight six highs; you will like it, the neighbors will like it, and the jack ass tailgating you will like it.
PostPosted: Thu Jan 03, 2013 6:14 am
I guess I did some good researching then. I haven't been able to find a clip of the HP2 on a slant six, but everything I've read has suggested that it kills the drone quite nicely.
It's a pretty spendy muffler though. Does anyone know of any alternatives? I'll probably just go with the HP2 and the 40 but I can't help but wonder if there is something else.
PostPosted: Thu Jan 03, 2013 6:28 am
I think that muffler choice is a matter of personal taste...I prefer mine a bit on the loud side, only because I have significant hearing loss(not caused by loud exhaust either)....this allows me to shift by hearing the engine's tune...quiet stock systems are fine on daily drivers, but I love to hear my hot rods. 8)
1956 Dodge 1/2 ton w/318,..1952 Ford 1/2 ton w/Hemi,..1940 Plymouth Business Coupe w/flathead six, dual carbs, and headers
PostPosted: Thu Jan 03, 2013 6:34 am
Makes sense. My truck is my DD though and likely will be for years to come since I can't seem to kill it
 Post subject: Hp2
PostPosted: Thu Jan 03, 2013 9:36 am
I haven't found another muffler that will do what the HP2 does for the SL6. I have tried many.....in several configurations.
If your worried about too quiet with a 18" HP2 and a FlowMaster 70, you may want to try a FM Delta 50 with it.....
PostPosted: Tue Jan 08, 2013 10:31 am
I'll definitely go with the HP2 then.
Do you guys think it would be cheaper to buy the mufflers on eBay or something then bring them to a local shop to have custom pipes bent and installed or to have the shop source the mufflers as well as do the install?
PostPosted: Tue Jan 08, 2013 1:28 pm
I bought it from Summit on a coupon and handed it to the shop. The shops may mark it up.
