It is currently Wed Nov 25, 2026 11:09 pm
PostPosted: Tue Jan 01, 2013 8:28 pm
I am in the machine phase right now.
I am having my block cleaned and decked. Same with the head. I have the crank, rods and block being line honed. Cylinders are being honed. Camshaft is being ground to a more aggressive setup with new lifters/push rods.
I am eying a set of over sized valves and 318 springs.
My question is what valve cc should I shoot for? My other question is do I need to replace the pistons or will cast pistons handle the higher compression?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Wed Jan 02, 2013 7:37 am
Car Model: 1964 Valiant V200
Sorry valve CC?? Do you mean combustion chamber cc?
That depends on your target compression ratio, which in turn depends on the fuel you want to use, your induction system, exhaust and especially the specs of the camshaft you are using, particularly the intake valve closing point.
Or do you mean valve size? In that case, larger is better until you run out of space or have mechanical problems (cracking between seats, etc.).
Cast pistons are fine for any street-type build. Forged pistons for the stock rods aren't really available 'off the shelf' for the slant. The commonly-available Wisecos are designed to be used with a 198-length rod, and since stockers are hard to find that means new H-beam rods are the only logical choice.
You should not be boring or decking your block without pistons/rods in hand and an idea of the CR you are shooting for.
PostPosted: Wed Jan 02, 2013 8:24 am
I apologize on my terminology. I mean the area above the piston and into the head. So yes I meant the combustion chamber. As for compression ratio I am shooting for 9.5 to 10.0. The camshaft is being ground by Oregon Camshaft and we talked about I want to say a 410 grind. I told him I was shooting for 9.5 to 10 and he said since I was going street not to go to aggressive. It was indicated that this was a grind he has used in the past. The exhaust has already been upgraded to 2.5" from the manifold. 96 octane is my preferred octane.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Wed Jan 02, 2013 8:52 am
FYI,
You should always have your selected pistons "in hand" before doing the finish hone work on the cylinder bores.
A good shop will measure each piston and hone accordingly, to be sure all the clearances are set correctly.
A high quality cast pistons are fine at 10 to 1 compression.
PostPosted: Wed Jan 02, 2013 10:01 am
Right now they are just cleaning everything and making sure the block, pistons and so forth are good.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
 Post subject: A What?
PostPosted: Wed Jan 02, 2013 7:33 pm
I'm looking over my OCG sheet and I can find a .410 lift, but not a 410 grind # in the mech lobe catalog. At 9.5-10:1 I would be batting at a '791' with 230/230 @.050 .48x lift and lobes at 110 for best idle on street or 108 if feeling a little lumpy and closer to 10:1 compression....
PostPosted: Thu Jan 03, 2013 10:15 am
Thank you very good information and I can certainly pass that along to him. I spoke to him about a month ago and this month has not been good to me so I don't really remember the conversation well.
So with this information in hand can anyone help me figure out what I should be looking for in my combustion chamber?
I found these recommendations in another thread an they suggested this guy on ebay.
These are the valves:
http://www.ebay.com/itm/390518498267?ss ... 1423.l2661
And here are the Springs:
http://www.ebay.com/itm/390509729018?ss ... 1423.l2649
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Thu Jan 03, 2013 2:07 pm
Those valves and springs are a great choice. They are good to about .500 lift, many people have used them. My machinist measured seat pressure of 100 lbs at a 1.675 installed height and 275 lbs at .490 (my lift target). They bind at 1.060. The valves are not particularly large, perfect for a (theoretical) reliable street motor. There are lighter and better flowing valves out there, but for much more money. You will need to port or have ported the bowl area to make the most out of them but they can be run as-is. Have your machinist install hardened exhaust seats so the head will last longer. Also install bronze or iron guides and positive seals on the intake. Make sure they use .200 deep by 1.475 seats for the exhaust to ensure they don't break through into water.
PostPosted: Thu Jan 03, 2013 2:10 pm
You will need some new or used larger retainers for those springs. My machinist sold me some used ones from an unknown application for $3 each, which is probably an average price.
PostPosted: Thu Jan 03, 2013 3:24 pm
Awesome so I think I know have enough information to move forward. The only thing I lack is the combustion chamber. Should I leave it as is or what should I do? What kind of space should I be shooting for?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Thu Jan 03, 2013 5:09 pm
Most SL6 chambers are in the 54 to 60 cc range...
You have to measure to see what you have and 'do the math' to be sure the compression ends-up where you want it.
 Post subject: Uhhh...
PostPosted: Thu Jan 03, 2013 5:32 pm
This is kind of pertinent for the build .410 lift isn't much and a very short grind with low overlap event is going to ping on most fuels at 9.5+...If this is the grind then you are going to need to rethink everything back to stock-ish....or yard the timing out of it...
PostPosted: Sun Jan 06, 2013 1:09 pm
Well based on what was posted earlier I am going to go with this setup. As I said initially since I am doing the machine work anyway I figured I might as well spice things up.
"I'm looking over my OCG sheet and I can find a .410 lift, but not a 410 grind # in the mech lobe catalog. At 9.5-10:1 I would be batting at a '791' with 230/230 @.050 .48x lift and lobes at 110 for best idle on street or 108 if feeling a little lumpy and closer to 10:1 compression.... "
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Sun Jan 06, 2013 6:47 pm
I'm planning on a 346 grind cam instead for similar specs. But I've considered the 791 too. Lou (Dart270) has some opinions on LSA, he might step in here.
PostPosted: Mon Jan 07, 2013 12:51 pm
How does the 346 vs 791 grinds differ? What would be the benefit?
Keep in mind I am looking for a capable street machine.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
