It is currently Thu Nov 26, 2026 2:37 pm
PostPosted: Fri Jan 04, 2013 7:39 am
While adjusting the timing and moving the distributor around, I noticed that the distributor on my car was slightly different from the ones off the cars I had parted out. It has a spot on the back that looks like it is for adding lubricant(?) Small teapot shape with a spring loaded flapper lid.
It actually hits the block just before full advance.(with bottom plate at maximum adjustment.) What is it? Is it just for lubrication?-Thanks
1964 Dart GT
PostPosted: Fri Jan 04, 2013 9:22 am
6 Pack Dart
Yes it is for lubrication just don't get carried away with it.
Richard
PostPosted: Fri Jan 04, 2013 9:52 am
Nice. I have only ever seen one of those distributors, and that was on an early 60s full size Dodge sedan. The oiling cup was dropped from later distributors. I would keep that distributor and pay to have it fully rebuilt if it ever needs it. Just add a drop of 3-in-one or other lubricant to the oiler every now and then.
 Post subject: Wow.
PostPosted: Fri Jan 04, 2013 4:17 pm
Those are common on the 60's point distributors and were dropped in the very early 70's, along with the mainshaft being 'candycane' grooved to help with the oiling. (the 1972 points distributors are like the late EI distributors and no oiler and no shaft grooving)...Lube per instructions noted, be careful when removing from car it's not hard to damage ro knock out the oiler.
I got a whole bin of these guys....
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 4 guests
