It is currently Thu Nov 26, 2026 10:03 am
PostPosted: Fri Jan 04, 2013 4:45 pm
I asked this question a couple of years ago but never heard.
The Slant Six was designed to be very robust to the point that it can be used as a structural member of the chassis.
My question: Does the aluminum block have the same capability?
I would really like to know.
Ben
PostPosted: Fri Jan 04, 2013 7:31 pm
I personally wouldn't trust one but I have no solid data to prove that claim.
PostPosted: Sat Jan 05, 2013 12:18 am
Car Model: 64 Valiant
I don't think they are either, their just a die cast part, and don't have extra reinforcing ribs or much extra beefiness to them at all. Especially not having a solid deck surface.
PostPosted: Sat Jan 05, 2013 12:25 am
The only example would have been the Lotus. That was an Iron block.
PostPosted: Sat Jan 05, 2013 10:45 am
Car Model: Toad Wagon
Bingo, one side of the structural "box" of moncoque concept is missing.
As in a truss, all components must be represented or it's like a chain with a missing link. ie, the rest of the links can't do their jobs without it.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Sun Jan 06, 2013 8:52 am
I agree. Use an iron block if you want that kind of structural support. Note that an alum block with caps is 77-79 lbs vs. 165-169 lbs for a mid-60s - mid 70s iron block. Thus, there is about the same volume of material in the alum block compared to the iron block (2.7 g/cc for alum and 7.9 g/cc for steel/iron). Aluminum is less rigid than iron and its fatigue strength is quite a bit lower. If the alum block had more material, or a lot of gusseting, maybe...
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 23 guests
