It is currently Thu Nov 26, 2026 1:52 am
PostPosted: Sun Jan 06, 2013 5:13 pm
I set to work replacing this timing chain because I had discovered 8-10 degrees of slop when cranking the engine back and forth. It's taken apart now. I have no frame of reference (this is my first timing chain replacement), but this doesn't seem that bad to me. What do you think? Here's a video and a few photos...
<img src="http://im1.shutterfly.com/media/47a3df27b3127ccef259d2fc1a9e00000030O00EYtnDls3Zswe3nww/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/">
<img src="http://im1.shutterfly.com/media/47a3df27b3127ccef2589c9d3a9400000030O00EYtnDls3Zswe3nww/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/">
J.R.
Tucson, AZ
'68 Dart 270 with a '76-'80 engine
PostPosted: Sun Jan 06, 2013 5:31 pm
Yep. That's shot.
PostPosted: Sun Jan 06, 2013 5:45 pm
Looks shot to me as well,though you don't have much slack on the bottom compared to mine
Check out these photos of mine i replaced a couple of weeks ago.
When i took the timing chain cover off i went :shock:
Lot's of slack at the top and bottom.
I replaced mine with a Rollermaster Red Series dual row.
DRIVE IT,DON'T HIDE IT
PostPosted: Sun Jan 06, 2013 6:57 pm
Great. Thanks, guys. I was worried my work had been for nought. Two followup questions: do the gears look okay? Again, they seem fine to me, and from what I've seen and read truly worn teeth seem to come to more of a point. How often do those generally get replaced? Also, my '68 manual said something about an "oil slinger," but I didn't see that on this later-model engine. How/where do the gears and chain get oiled?
J.R.
Tucson, AZ
PostPosted: Sun Jan 06, 2013 7:09 pm
6 Pack Dart
I would change gears regardless why take a chance. The oil slinger wasn't present in a lot of slants. You can use one from a V8 think it's the 440.
Richard
PostPosted: Sun Jan 06, 2013 7:28 pm
Oil is delivered from the front main. It is slung out onto the chain from the back of the crank timing gear. Some of the new gears don't allow adequate oil to be dispersed. I think Doc had a description of how to accomplish the mod, but the thread it was in has broken photo links. :cry:
There are mods that can be done to improve oiling if you feel the chain isn't getting enough oil. For racing applications, a very small hole drilled at an angle to intersect the main oil galley just behind the cam gear can improve oiling. Another option is to drill a small hole through the front oil galley plug.
This can also be a great way to break drill bits. :lol:
The hole should be very small. Too big, and engine oil pressure may present a problem.
PostPosted: Sun Jan 06, 2013 7:57 pm
That's good to know! I don't already have enough ways to break drill bits! :D
PostPosted: Mon Jan 07, 2013 8:19 am
Thanks again, guys. ANOTHER followup question (I promise this is the last one... probably): the large camshaft gear comes off easily, what about the small crankshaft gear - what's the best way to get that off?
J.R.
Tucson, AZ
PostPosted: Mon Jan 07, 2013 8:52 am
6 Pack Dart
A good 3 jawed gear puller. :shock: :lol:
Richard
 Post subject: Yep...
PostPosted: Mon Jan 07, 2013 6:15 pm
I use a beefy 2 jaw puller, and a little judicious heat on the gear from my buddy the MAPP gas torch...
Either one gets it done...
:wink:
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 3 guests
