It is currently Thu Nov 26, 2026 1:20 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
 Post subject: 6 of one 1/2 dozen...
PostPosted: Mon Jan 07, 2013 6:26 pm
How does the 346 vs 791 grinds differ? What would be the benefit?
Durations at .050:
791 is 230/230 with a .483/.489 lift similar to the Erson 280 cam
346 is 234/228 with a .476/.479 lift making the intake a little longer...maybe a little lumpier but will make good use if dialing
in some ram air...
If going 10:1 both cams would be OK to use...the stocker 346 has a 106 LSA and may have a little more torque that would be normally be given up by longer durations, the 791 is a good all around with a little more lift
(this may or may not be pertinent depending on how much porting you are planning to do and the O/S valves used...in some cases it might be just chasing the pennies in the wind...or it may depend on how you like your idle).
PostPosted: Tue Jan 08, 2013 4:17 pm
Car Model: 1964 Valiant V200
I was planning 346 because it has more intake duration, which is recommended by people who know more about the slant than I do. Also it has tighter lash specs so I figured (possibly wrongly) that it would be quieter.
I do like the additional lift without additional duration of the 741 though.
But I imagine either would work pretty good. I might try both, they are cheap enough (although you have to pull the motor to swap them usually).
 Post subject: 346
PostPosted: Tue Jan 08, 2013 5:33 pm
hello. i just finished putting a long rod 225 in my truck with the 346 cam. i chose this also because of the recommended longer intake duration. the sheet that came with the cam showed 108 lsa. i installed it at 100 intake center line. it had a pretty lopey idle at the .012 valve lash and as recommended by Lou, backed them off to .020 in/.024 ex and that greatly improved the idle and still runs quiet so far. i am still fine tuning, my son and i took it for a short test drive yesterday :D :D and had no apparent issues. getting exhaust on thursday.
member DadTruck ran my engines numbers (thanks DT) on his desktop dyno simulator. the program shows a nice steady torque up to 5000 rpm. should be a good street cam. here are the HP and torque graphs;
at the wheel
at the flywheel
andy.
84 D100 /6 long rod 225
86 D100 /6 my sons w/offy intake/weber carb
2016 buick regal turbo
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 1 guest
