It is currently Sun Nov 15, 2026 11:51 pm
 Post subject: Transgo Tf-2
PostPosted: Mon Jan 07, 2013 8:58 pm
I picked up one of these for the Duster. Can you really install the kit without removing the transmission, or is it better to do so?
And just how hard is the install, I haven't installed a shift kit in 30 years and that was a TH400 in a '66 442 using a B&M kit.
PostPosted: Mon Jan 07, 2013 10:05 pm
6 Pack Dart
All you are doing is changing things in the valve body, why pull trans?
Richard
PostPosted: Tue Jan 08, 2013 9:55 pm
Don't know, hence the question. I guess that is a vote to not pull the trans.
PostPosted: Wed Jan 09, 2013 4:26 am
Drop the pan, adjust bands, install kit, refill and enjoy.
Be sure to use a torque wrench, valve bodies are susceptible to warping which causes binding of moving parts and internal leaks from improperly torqued bolts.
 Post subject: .
PostPosted: Thu Jan 10, 2013 6:51 pm
The only thing in the main case that needs changed is the low-reverse servo spring. Be sure NOT to mix up the springs in the valve body, as several of them look similar
