It is currently Wed Nov 25, 2026 6:52 am
PostPosted: Tue Jan 08, 2013 7:16 am
What is the correct ballpark exhaust temp. On the #6 runner. I have a huge difference in temps.
1- 318*
2- 350*
3- 361*
4- 359*
5- 355*
6- 242*
Pretty sure this is not normal. I do have issues keeping the car idling in gear that started recently. Thinking this is causing the problem. I'm going to check the plug condition and runner for a possible vacuum leak this afternoon. Any feed back is appreciated.
74 Dart Swinger, supersixed.
PostPosted: Tue Jan 08, 2013 8:46 am
WAG is it is ingnition related. But maybe some one that really tunes em to the nth degree will chime in and have an idea...
MRO....
PostPosted: Tue Jan 08, 2013 6:24 pm
Is the pipe plug in the #6 runner
or
is there a vacuum hose connected to it?
PostPosted: Tue Jan 08, 2013 6:51 pm
Vacuum, is going to the brake booster. No plug.
I got in late tonight so I was not able to look at anything. Will try again tomorrow.
 Post subject: .
PostPosted: Tue Jan 08, 2013 6:55 pm
emsvitil is close on this one, check for a leaky brake booster,or vacuum lines
PostPosted: Tue Jan 08, 2013 7:28 pm
What does the #6 runner usually run at as far as temp? Should it be consistent with the others..
I will try plugging the booster and retaking temp readings tomorrow.
PostPosted: Sat Jan 12, 2013 3:25 pm
Well I found no vacuum leaks, changed the plugs with nkg's checked compression (160) ignition to all cylinders were good. I went ahead and relashed the valves a little lighter to .013 and .018. This smoothed out the Idel. they were at .012 and .015 (it is a comp cam spec recommend .010 and . 012 but we all know that's to tight)
The temp is still low on #6 exhaust runner.... Any ideals. Cars runs good.. Should I be worried about the low temp? Can anyone give me some feedback on what there's reads. A few pics on the link below.
http://s1270.beta.photobucket.com/user/ ... %20rebuild[/url]
PostPosted: Sat Jan 12, 2013 3:33 pm
Corrected link. I think...
http://s1270.beta.photobucket.com/user/ ... mail_share
PostPosted: Sat Jan 12, 2013 4:23 pm
It all sounds cold for exhaust.
Check valve lash.
