It is currently Wed Nov 25, 2026 7:26 pm
PostPosted: Wed Jan 09, 2013 7:46 am
i finally found out why my slant died on me 2 and a half months ago 5 of the six intake pushrods are bent :shock: :x :evil: :oops: :cry: :? and this is because i didnt listen to my dad and change the gas tank and it pumped a mixture of dead gas and good gas in to the motor. it was a mess i had to rebuild my carb because it was fulll of sediment and flush every thing out. the varnish was so bad it made cyl # 5 intake valve get stuck shut i fixed that.im just glad it wasn't as bad as i thought. :roll: :D
trying to keep it low key here in my Valiant200
PostPosted: Wed Jan 09, 2013 10:20 am
This is a good learning experience for you...Someday when you get old, you can pass your wisdom on to them "damn kids" !!...I hope you got her running again !!
1956 Dodge 1/2 ton w/318,..1952 Ford 1/2 ton w/Hemi,..1940 Plymouth Business Coupe w/flathead six, dual carbs, and headers
PostPosted: Wed Jan 09, 2013 11:14 am
One tip...
I always disconnect the inlet side of the fuel pump and use a long hose and a 1 gallon can of fresh gas, to start any vehicle that has been sitting for a while.
