It is currently Wed Nov 25, 2026 3:51 am
PostPosted: Sat Jan 12, 2013 5:07 pm
will it hurt to run the engine with the oil pressure relief valve sticking if so could i fix this with out removing the pump from the car
trying to keep it low key here in my Valiant200
PostPosted: Sun Jan 13, 2013 12:30 am
Do you have too much oil pressure or none?
Too much will do a lot less damage than none.
Depending on what chassis the motor is in will determine the ease of getting to the plug. Some are way easier than others.
PostPosted: Sun Jan 13, 2013 12:13 pm
its a 69 valiant i know i have oil pressure but the dummy light comes on in about ready to put a gague on it and do away with the light
PostPosted: Sun Jan 13, 2013 3:48 pm
The pressure switch could be bad and giving you a false low pressure alarm.
I would tee-in the oil pressure sender so that the light still works. This would give you an immediate warning if you lost oil pressure.
PostPosted: Sun Jan 13, 2013 6:51 pm
What oil filter are you running?Frams are the worst.
PostPosted: Mon Jan 14, 2013 12:00 am
im running a puralator 300001 the yellow one, friday im putting the oil pressure gauge in the Valiant
