It is currently Sat Jun 13, 2026 7:11 am
PostPosted: Sun Jan 13, 2013 8:56 am
Can someone explalin to me how to remove my dash? Its a 1965 Plymouth belvedere. I don't know what bolts to remove, what to leave, etc.
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
PostPosted: Sun Jan 13, 2013 9:41 am
The full dashboard will require removal of the windsheild to get at the bolts holding the back of the dash to the cowl...
PostPosted: Wed Jan 23, 2013 5:30 pm
Also remove the lower plastic kick panel's, underneath the lower dash frame, and loosen one bolt per each side of the dash, then with all the 5-6 small bolt's removed, , under the windshield/rubber, as per mentioned in the previous post)
the dash may have a brace too, under the middle of the dash to the cowl, so check for that too, and dashboard should be able to be removed.
