It is currently Sat Jun 13, 2026 5:20 pm
Post new topic  Reply to topic  [ 1918 posts ]  Go to page Previous 135 36 37 38 39128 Next
PostPosted: Wed Jan 02, 2013 7:49 am
:? $$$$$$$$$$$$$$$$$$$$$$$ :lol:
PostPosted: Wed Jan 02, 2013 9:17 am
Car Model: 64 Valiant
Thanks Richard,
That is a very good video. I guess I will build a fixture and check them out the "right" way. I appreciate your helping me to learn!
Rick
The main thing to remember Rick is to make the portion of the fixture that the B/E is supported by a bearing or something that is not binding, that will help it repeat, and the same for when you flip it around and do the small end(which really isn't necessary on an inline, the total weight is all the crank recognizes since it doesn't utilize bobweights to balance them). Also, you can remove weight from the piston by using a carbide burr(for aluminum) and grind on the pin support bosses on the underside of the piston. Piston weights are a lot closer than they used to be, before it wasn't uncommon to have a 7-8 gram variation between several in the same set, now they can be only 1-2 grams between them.
PostPosted: Wed Jan 02, 2013 12:42 pm
And a Hole saw, Chop Saw angle Grinder, and cutoff wheel..
all that junk costs money I guess.
PostPosted: Wed Jan 02, 2013 1:03 pm
No matter how fast it goes you'll want it to go faster.
Oh so true! I hope it runs 13.50-13.70 when I'm done this year. We shall see. When I talked to Mike about a new head, maybe for next winter, he asked me how fast I wanted to go. I told him my lifetime goal would be to run a 12.99. He said, Ok I will put you down as 12.99. Sounded pretty good when he said that!! :lol: :lol: Super nice Guy to talk to also.
Mine were all within 1G. I did not touch them.
Rick
PostPosted: Wed Jan 02, 2013 2:33 pm
:D
PostPosted: Wed Jan 02, 2013 5:17 pm
See Rick, I told you to reach out to them corn Huskers...
Now you'll have a 12.99 blue fire snarlin valiant after talkin with Mike!
Too Bad Mike, the Goodmans, Howard Davis and the other midwest slanters do not get out here on the east side very much.
Aww Shucks,
PostPosted: Wed Jan 02, 2013 11:15 pm
Mike is a bad influence on people. I was happy running mid-19's before I met him. :lol:
PostPosted: Thu Jan 03, 2013 5:26 am
It's a sickness, A SLANT sickness,Ric, just yankin' your chain a bit. If all goes well We are looking foward to making a few races at M/D this summer.
Greg,Rumor has it that there may not be a Mopar C.G.M. race at Pittsburgh due to new people running the track........
PostPosted: Thu Jan 03, 2013 8:46 am
Romeo,
Yep. I am okay with that.. I may just tow out to maple grove in reading for their mopar weekend..
Mopar action Mega Series June 22-23..at maple Grove
Heck that's close for all the east side racers and we can toss it around at the banquet and see if they would want slants there.
PostPosted: Sat Jan 12, 2013 9:10 am
I stopped by the machine shop Thursday and picked up the old rear cam bearing. I wanted to keep that for checking cams hole alignment. The block was in the tank getting cooked as we talked and the crank should be done by mid week. So he hoped to have everything done by the 18th. Wow, that is ahead of schedule.
I got all the intake port roofs done on the head. Knocked down all the guides and have the bowls roughed in. A couple more hours on the intakes and they will be done. Then it is over to the exhuast ports.
Rick
 Post subject: Cost update
PostPosted: Sun Jan 13, 2013 1:50 pm
Parts list + price
Complete 68-70 engine------------------$35 E-Bay
Reconditioned 198 rods - ---------------$90 PAW years ago
New 2.8L chevy pistons / Rings -------$35 E-Bay
Reground Cam .513/506 / 290 -------$87 Oregon Cams
Modified oil pump and hardened gear--$75 Doc
New Lifters -------------------------------$24 E-Bay
New Chromoloy Push Rods-------------$46 E-Bay
Engine Builder Valves -------------------$87 E-Bay
New Valve Springs ----------------------- $46 E-Bay
Cylinder head work -----------------------$200 Machine shop
Sonic check block ------------------------$ Free
JP Billet timing set -----------------------$79 E-Bay
Clevite Rod Bearings---------------------$19 E-Bay
Clevite Mains -----------------------------$ 38 E-Bay
Cam Bearings -----------------------------$ 22 Rock Auto
Felpro Gasket set -------------------------$54 Rock Auto
Windage Tray & Scraper -----------------$___ ? Mike Jeffrey
ARP Rod Bolts ---------------------------$ 57 E-Bay
Rick
PostPosted: Sun Jan 13, 2013 2:57 pm
6 Pack Dart
Rick would the E-Bay $pechial sound like a good name for your motor? :lol: :lol:
Richard
PostPosted: Sun Jan 13, 2013 4:31 pm
Yes, It may be!! :lol: :lol:
PostPosted: Thu Jan 17, 2013 9:26 am
When I told Jefferies I wanted a head that might bee able to break into the 11s,he goofed and built a head that got me a 11.42 na and 10.57 on the spray.BEST money I spent on the car,and I beleive the major reason I have 10 records.I cant thank Mike enough.Mark
PostPosted: Thu Jan 17, 2013 9:28 am
I got all the intake ports and runners done. Now I can move on to the exhausts.
Talked to the machine shop and the block is bored, decked .005 just to clean it up and the cam bearings are in. Just waiting on the crank, and it can all be brought home.
Rick
