It is currently Fri Jan 02, 2026 10:29 pm
PostPosted: Wed Jan 23, 2013 8:29 am
I was wondering if anyone makes hid kits for 60's era cars, and if so, where to get them.
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
PostPosted: Wed Jan 23, 2013 11:03 am
Gah! :evil: Where's Dan when you need him! Google Dan Stern Lighting and start reading.
PostPosted: Wed Jan 23, 2013 7:12 pm
The short answer is yes. However a proper quality kit is Very costly. HID is overrated. If you see a HID kit on ebay it is junk and likely illegal.
I agree with the statement to read www.danielsternlighting.com he is a mopar guy and the absolute expert on all things concerning automotive lighting.
PostPosted: Wed Jan 23, 2013 7:29 pm
Ok, I just wanted brighter lights, and I had interest in purple h.i.d.'s,
2002 Subaru OBS
PostPosted: Wed Jan 23, 2013 8:31 pm
This commendable, so long as you also make sure you have a proper beam pattern.
Uh, ok, but check your local laws about permissible headlamp colors.
I also recommend www.danielsternlighting.com Dan knows his business about headlamps.
PostPosted: Thu Jan 24, 2013 3:49 am
If I recall correctly, you can use GE Nighthawks to significantly improve your lighting. These simply "bolt in" with no modification necessary.
Dan used to recommend them very highly over stuff like the Sylvania Silverstars, etc.
Try the Nighthawks. If you decide they are still not enough then you can explore Cibie and other options.
- Mac
(PS: Also be sure that you have 12.6 volts (or better) at the lamp socket with the lights on. The wiring in our old cars was notoriously poor. You might wish to upgrade with headlamp relays)
PostPosted: Thu Jan 24, 2013 5:01 am
Recently I purchased a headlight wiring upgrade from Dan that adds two relays, and larger gage wire which eliminated voltage drop caused by under sized factory harness. There was enough brightness improvement in lumen output from standard lamps that I have yet to purchase and install Nighthawk lamps.
PostPosted: Thu Jan 24, 2013 5:59 am
Agreed, do the relay mod and use good Halogen sealed beams.
That's all you need. Please, do the other drivers on the road a favour and don't use coloured headlights.
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
PostPosted: Thu Jan 24, 2013 6:57 am
+1 !!
Most of those aftermarket "colored" lights are very distracting. As are most HID systems- the OEM ones provide great visibility for the driver, but any bump or rise puts lots of glare into oncoming drivers' faces.
(Oooooo! look at the pretty lights :o )
63 Valiant Wagon
225 - 4 bbl
PostPosted: Thu Jan 24, 2013 10:47 pm
My untrained eyes found both the GE Nighthawk and Sylvania Silverstar to be about the same (huge) improvement on my rigs.
I remember once leaving work behind another guy's 80's chevy truck, the work driveway dropped down where it met the road. I was a car length or two behind him as he went to pull out, and my headlights were brighter on the road in front of him than his were...
PostPosted: Thu Jan 31, 2013 1:07 pm
Thank you all, I will get the kit and try one of the two said bulbs. Also, has anyone found a way to get brighter turn signals?
2002 Subaru OBS
PostPosted: Thu Jan 31, 2013 5:04 pm
[quote]Thank you all, I will get the kit and try one of the two said bulbs. [/quote]
Dan recommends the GE Nighthawks because of their superior lens and beam pattern.
[quote]Also, has anyone found a way to get brighter turn signals?[/quote]
One thing you can do to improve tail, brake, and parking light brightness is to disassemble their housings, clean the lenses & reflectors, and paint reflectors with fake chrome/sliver from a rattle can if they won’t clean up. I did this to my 67 Dart and it made a big difference when 45 years of crud was removed from the internal surfaces of these lights.
Also the new gaskets stopped a lot of combustion fumes entering the trunk and cockpit that were passing around the old dry lense gaskets
One has to be careful not to damage these old plastic lenses. Also before you attempt this cleaning process, order a set of gaskets from [url=http://detroitmuscletechnologies.com/]Detroit Muscle[/url] to replace the old rock hard dust leaking factory originals. His gaskets are high quality exact reproductions of what Chrysler used, and their service and prices are good.
Somewhere on this site I think slantsixdan has posted a list of brighter bulbs for brake & directional applications sold by Honda dealers that can be used. Search for “Honda bulbsâ€￾ by: slantsixdan
