It is currently Tue Jun 16, 2026 3:48 am
 Post subject: cams
PostPosted: Sat Nov 22, 2003 4:05 pm
Has anyone used cliffords 260 cam. I'm currently using it in conjunctiowith thier maniflod and headers, but I'm a bit underwhelmed :? . I was expecting more. I'm about to build a new motor w, decked a ported head 8) but I'm wondering if I should go with a more agressive cam, like comp's 264? any Imput would be great.
Oh by the way, the motor is in a 64 dart, Rebuilt PB auto w/ shift kit and V8 clutches, and 7.25 rear w/ 2.76 gears :? (want to change that). The motor still has points and is running a holley 390, and the plugs a burnig pretty clean.
Never under estimate the power of stupid people!
PostPosted: Sat Nov 22, 2003 7:40 pm
You really need to get away from that 2.76 gear, that is hurting you combo.
Did you degree-in the Clifford cam? That should run pertty strong with 4 degrees of advance on it.
Also check you distributor advance curve, a faster advance may help.
 Post subject: advance
PostPosted: Sat Nov 22, 2003 11:33 pm
I really want to put some 323 gears in it. I'm currently working on modifying a spare distributor I have laying around an see what happens.
When I bought the cam I was afraid of going too radicle a cam with the stock stall converter. Now I'm wondering if I was too conservative?
I didn't degree the cam :oops: I installed it straight up.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
