It is currently Sat May 23, 2026 5:41 pm
 Post subject: main bearings
PostPosted: Sat Jan 26, 2013 11:25 am
sealed power and clevite both are hanging out of main journels any ideas or thoughts this is a 67 225 block[img]/Users/JHouston/Pictures/iPhoto%20Library/Masters/2012/12/11/20121211-174504/IMG_0415.JPG[/img]
PostPosted: Sat Jan 26, 2013 3:08 pm
You will need to host the photo someplace like photobucket.
Can't see the photo.
PostPosted: Sun Jan 27, 2013 9:02 am
Sounds like forged crank bearings in a cast crank engine.
Vote #2 for a photo.
PostPosted: Sun Jan 27, 2013 3:21 pm
He did have pics over at FABO but they are gone now. It did look, to me, like a cast crank block with forged main bearings.
 Post subject: mains
PostPosted: Mon Jan 28, 2013 12:43 pm
go to john henry houston on face book and you can see the way the bearings are sitting the block
PostPosted: Mon Jan 28, 2013 1:26 pm
http://www.slantsix.org/forum/viewtopic.php?t=4434
 Post subject: Re: mains
PostPosted: Mon Jan 28, 2013 1:32 pm
No, not everyone is on that site.
Rod :roll:
PostPosted: Mon Jan 28, 2013 4:46 pm
Rod :roll:
X2, I don't do facebook. I spend enought time here.
PostPosted: Mon Jan 28, 2013 5:35 pm
<img src="http://i1353.photobucket.com/albums/q661/duck0121/IMG_0414_zps424da3b1.jpg" border="0" alt="slant 6 bearings photo IMG_0414_zps424da3b1.jpg"/>
PostPosted: Tue Jan 29, 2013 9:12 am
Yes... you are showing a forged crank main bearing insert. (2 oil feed holes)
Go get a set of mains for a 76 and newer SL6, that should fix it.
(also check your con rod bearings... those are also different for the cast crank engine)
On ebag
PostPosted: Tue Jan 29, 2013 2:28 pm
but the block is marked 67 225r
PostPosted: Tue Jan 29, 2013 2:59 pm
Could the "r" stamping be the letter "E"??
PostPosted: Wed Jan 30, 2013 10:13 am
ordered some new bearings and the block does have two oil passages thax for the help
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
