It is currently Sun Nov 22, 2026 6:44 pm
PostPosted: Tue Jan 29, 2013 10:16 am
I got a head off a 1980 truck to work on getting my efi setup to fit and do some port matching/ clean up/ etc. while my motor is still together and running. Will that head have hardened exhaust seats from the factory for sure? Do they last or are they very shallow?
 Post subject: Yep...
PostPosted: Tue Jan 29, 2013 5:42 pm
If it's a peanut plug head it will have hardened seats...
So far as I've seen if they do a valve regrind you are gambling, if this is a Hipo engine with O/S vavles you are going to have the machinist install new ones.
PostPosted: Wed Jan 30, 2013 5:27 am
If you’re considering oversized valves, my machinist told me chances were good when seat is cut larger he would be into non hardened material. I had him install larger hardened seats; I think that was a $6 per valve additional charge four years ago.
