It is currently Wed May 20, 2026 3:44 am
PostPosted: Wed Jan 30, 2013 1:30 pm
Car Model: 1964 Dart 270
Harmonic balance play? Just wondering how much wobble should you see when watching your motor run? Its a 1964 Dodge Dart 225 slant six......
PostPosted: Wed Jan 30, 2013 1:57 pm
No wobble, the damper should spin "true".
PostPosted: Wed Jan 30, 2013 2:39 pm
Doc if its suppose to spin true what might cause it to wobble? Thanks for the help..........
PostPosted: Wed Jan 30, 2013 2:58 pm
These damper are 2 piece with a rubber insert between the outer ring and the inner hub. Look at it closely to see if the inner hub is spinning true.
Mechanical damage will knock the outer ring "off centerline".
(a hard "bump" to the damper, prying, hammering, or using an incorrect puller can "shift" the outer ring)
PostPosted: Wed Jan 30, 2013 3:00 pm
Ok Doc I will check it Thanks again for your help......
Users browsing this forum: Amazon [Bot], Google [Bot] and 12 guests
