It is currently Thu May 28, 2026 2:03 am
Post new topic  Reply to topic  [ 75 posts ]  Go to page 1 2 3 4 5 Next
 Post subject: New Product Development!
PostPosted: Thu Jan 31, 2013 7:16 pm
Car Model: 64 Valiant
At Charrlie_S' recommendation, I am inquiring about thoughts for new product development for the Slants. The reason im asking is because I just recently acquired an aluminum foundry that was shutting its doors after almost 60 years in business. Also, prior to this, in this past December, I also bought out a racing aluminum cylinder head manufacturer that was specializing in some inline 4 and 6 cylinders of another brand for the Midget racing crowd, and along with that acquired all the casting patterns to produce their cylinder heads, valve covers, timing covers, a mechanical fuel injection intake manifold and a carbed intake manifold as well as patterns for a race block. So, I am seeing tremendous crossover potential to offer from concept to finished product, almost anything within reason for the Slant's.
So, with the exception of a DOHC, 4 valve aluminum head, :roll: what else could be put onto the drawing board for the Slant.
PostPosted: Thu Jan 31, 2013 7:59 pm
-A Quality Thermostat Housing
-Timing Cover with a removable face
-Bad Ass RearEnd Cover for a 7 1/4 :lol:
-Driverside Alternator mounts
-Carb. heat shields
1964 Dart GT
PostPosted: Thu Jan 31, 2013 8:08 pm
Aluminum intake manifolds with fuel injection bosses cast in place
Aluminum pieces for the Dart Lite and Feather Duster (yeah, I know its not going to happen)
HEI module and coil mounts
A/C brackets for later style compressors (also small enough to fit in a van) Get with Charlie S on this one
Rear window louvers
Interior bits- Instrument cluster housing for aftermarket gauges for the late A bodies, door handles, window cranks
PostPosted: Thu Jan 31, 2013 8:12 pm
Car Model: '23 T-bucket
Hmmmm;
Limited casting of aluminum trans adapters/bell housings?
A "shorty" tail shaft housing for the A904?
Modified oil pump housings? (I'm thinking along the lines of the right-drive Aussie oil pump.)
Water pump adapter/housing that would accept a B/RB water pump? New/rebuilt water pump availability is, or will start getting less and less. After all, this engine really isn't the most popular one around.
Something new and different for a valve cover?
"Hats" or pressure boxes for turbo/blower applications?
There's a number of possibilities for a foundry, if one wanted to persue it. Trim pieces for older cars that were originally pot-cast, you could now cast in AL. The buyer could then go to the trouble of having it plated.
Just a few idears tossed out for the fun of it.
Roger
PostPosted: Thu Jan 31, 2013 8:40 pm
Car Model: 1964 Dart 270
Aluminum intake, for a one barrel set up?
1964 Dodge Dart 270 four door. Three speed automatic 225 Slant with a Carter BBS carb.Image
PostPosted: Thu Jan 31, 2013 8:52 pm
Sell shares and make it a slant six community owned foundry. Get a board of directors who would vote on product development and funding and raise funds for the projects form the slant six community. Stockholders could get cash dividends or trade their dividend for a discount on parts.
PostPosted: Thu Jan 31, 2013 9:33 pm
Hey thats not a bad idea, I wonder what the buy in would be?
Harmonic damper with 6/8 rib serpentine pulley.
PostPosted: Thu Jan 31, 2013 11:13 pm
-Carb. heat shields
All great ideas, and would be easy on the pocketbook as well!
As for the rear cover, what were you thinking....fins or plain that could be polished, built in cap girdle....? Need a cover to get dimensions from.....anyone!
PostPosted: Thu Jan 31, 2013 11:18 pm
What kind of intakes, 2 bbl, 4 bbl, or long tubular plenum with short runners and throttle body at the front of plenum....
What parts for the Dart Lite and Feather Duster?
Having to make money takes all the fun out of it. :P
PostPosted: Thu Jan 31, 2013 11:20 pm
Im already thinking of several different styles, i'll add this one to the list as well.
PostPosted: Fri Feb 01, 2013 1:48 am
That would need the services of a LAWYER 'eh Reed? :lol:
regards,Rod :lol:
PostPosted: Fri Feb 01, 2013 5:39 am
An aluminum flywheel and bell housing for a T-5 swap.
Fuel injection intake and rail combo for bocsh injectors.
Serpentin belt and pully system.
Aluminum hubs for disc brake conversions on the 73+ abody spindle.
Aluminum H-beam connecting rods.
Baffeled oil pans.
A front timing cover that is removable for quick timing changes but also has a built in adjustable cam button.
Carb plate for the offy and clifford manifolds that are always missing.
Super six linkage and kickdown.
A thermostat housing that has provisions for a gm temp sensor.
PostPosted: Fri Feb 01, 2013 6:19 am
Congrats on your exciting purchases/acquisitions! Sounds like a new frontier is ahead of you, and you will have a lot of sound decisions to make.
I have plenty of ideas for parts, and can give you an idea of what would likely sell from the long list people have made here. Hope to see you at the banquet and we can bounce ideas around in real time! Feel free to call me too.
PostPosted: Fri Feb 01, 2013 6:35 am
maybe a Drag Axle!
but I would be Happy with the Thermostat Housing! :D
1964 Dart GT
