It is currently Tue Nov 17, 2026 4:56 am
PostPosted: Thu Jan 31, 2013 7:06 pm
I have a very noisy 7 1/4 and want to replace it with a 8 3/4 rebuilt sure grip that I own. The 8 3/4 has new 10' brakes, shoes and wheel cylinders is complete with new small bolt pattern drums bearings etc. The front of the car has been installed with 10' drums and a dual master cylinder. It is a daily driver. What else do I need to complete the job?
PostPosted: Thu Jan 31, 2013 8:07 pm
if this rebuilt 8.75 is the correct length and has the spring perches set to match yours, you will need to shorten your driveshaft and get a rear universal joint that fits the 8.75 yoke. Check here for measurements you'll need
ATB
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
PostPosted: Fri Feb 01, 2013 8:44 am
You will also need the shock plates and U-bolts for the 8 3/4.
PostPosted: Fri Feb 01, 2013 8:45 am
As mentioned the driveshaft is shorter for a car with an 8 3/4 than for one with a 7 1/4. You also need U-bolts and the plates which go under the springs and carry the lower shock mounts. This is due to the 8 3/4 having 3" diameter axle tubes and the 7 1/4 having 2 1/2" tubes. Unless you have a large yoke on the 8 3/4 the U-joints will stay the same. You may need to keep your old parking brake cables.
PostPosted: Fri Feb 01, 2013 10:33 am
Driveshaft will need to be shortened about 1-3/4".
If you are lucky your 8-3/4 will have the 7260 yoke on it and your small u-joint will work.
If it has the 7290 yoke there are adapter joints available. :D
 Post subject: chart info
PostPosted: Sun Feb 10, 2013 8:19 am
A chart have says 2.26 inches--
PostPosted: Sun Feb 10, 2013 8:31 am
I always get the new rear installed, then measure-out the needed driveshaft length...
There is just too much variation, vehicle to vehicle.
Users browsing this forum: Amazon [Bot] and 1 guest
