It is currently Wed May 13, 2026 9:29 pm
PostPosted: Sun Feb 10, 2013 9:19 pm
Okay so I have now bought my Super Six and a Carter BBD. I still need to do the kickdown linkage and gas pedal.
If anyone has a gas pedal kicking around to finish the conversion I would be willing to discuss it.
I found on eBay a Kickdown Linkage. How does this look?
http://www.ebay.com/itm/GEARHEAD-CHRYSL ... 42&vxp=mtr
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
 Post subject: Looks about right...
PostPosted: Sun Feb 10, 2013 9:35 pm
Looks similar to the Lokar Cable system (if exactly as pictured) but at a lower cost.
If you can't find a 1966 A-body gas pedal and a 1974 V-8 throttle cable (best match for the application). I have the throttle cable, but only have post 1967 pedals which can be made to work...
PostPosted: Thu Feb 14, 2013 6:02 pm
I have a gas pedal cable I pulled at a junk yard, it 21" in total length.
Not sure if it will work for your application cause i never tried to install it, but if you want it you can have it for what I paid... 6 bucks.
plus shipping to you.
74 Dart Swinger, supersixed.
 Post subject: Done...
PostPosted: Thu Feb 14, 2013 9:21 pm
I already sent him a pedal and supersix throttle cable (they are shorter than the stock 1 barrel cable...21" would work great for a hyperpak or Aussiespeed though).
:wink:
PostPosted: Fri Feb 15, 2013 10:01 pm
DusterIdiot I received the pedal and throttle linkage today thank you. It looks like it will work well.
The last thing I need or need to figure out is the transmission kickdown linkage. Charlie had suggested going to a local bike shop and I am good with that but he did not give enough info for me to figure it out.
Based on the pics I have found it looks like the throttle cable attaches to the top of a moon shaped bracket while the transmission linkage attached on the bottom with springs pulls. The problem is I have not seen a single image of the transmission side. Does it connect all the way down under the car or does it connect to the existing linkage?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Sat Feb 16, 2013 6:07 pm
Anyone?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
 Post subject: It...
PostPosted: Sat Feb 16, 2013 7:26 pm
The Lokar setup has a bracket that is bolted under one of the rear bolts on the tailshaft to body assembly on the tranny. The end of the cable has a bolt that bolts through the stock kickdown actuation arm on the tranny.
PostPosted: Sat Feb 16, 2013 8:55 pm
6 Pack Dart
See in this post, if you scroll down you will see pictures of cable hookup.
http://slantsix.org/forum/viewtopic.php ... e+kickdown
Richard
