It is currently Thu May 28, 2026 8:53 am
 Post subject: Pilot bushing
PostPosted: Wed Feb 13, 2013 12:11 pm
Is the /6 pilot bushing in the crank the same as sb?
I need to change mine before I put the 3 speed in the car.
I saw a roller pilot bushing on Mancini Racing for smallblock, will it fit my /6.
Thanks.
PostPosted: Wed Feb 13, 2013 12:16 pm
The roller pilot bearings only fit large counterbore cranks as they fit the torque conveter pocket. The bushings are the same though.
 Post subject: As Josh Said...
PostPosted: Wed Feb 13, 2013 12:26 pm
Per Joshua this will only cranks manufactured for the 1968 model and later.
PostPosted: Wed Feb 13, 2013 12:32 pm
My charger is a 68 and the engine is matching number.
But I'll have to measure the crank and see how big it is.
Thanks
 Post subject: Yep...
PostPosted: Wed Feb 13, 2013 12:38 pm
Just the pocket diameter....1.805 ID or so should be correct.
-D.idiot
PostPosted: Thu Feb 14, 2013 7:16 am
Thanks you -D.idiot :D
PostPosted: Thu Feb 14, 2013 12:20 pm
don't forget to fill bushing before install.....set on thumb,fill with oil,press with finger till oil flows out side of bushing....koolest thing I ever seen ...now you h
