It is currently Sat May 16, 2026 3:19 pm
 Post subject: Engine ID!
PostPosted: Sun Feb 17, 2013 6:26 am
HI!
The engine in my -64 valiant has been replaced, it´s still a 225" but i would like to know more.
On top of the block ( over nr 1 sparkplugg)it´s says: I 225 R 1203 E
Under the intake manifold ( in the casting) it´s says:
330-3
6 16 81 IF
I live in Sweden and english is not really my language
so i apologize for any misspellings
Best regards
Mrroth71
1964 Plymouth Valiant V-200 conv
PostPosted: Tue Feb 19, 2013 12:20 am
correction:
On top of the block ( nr 1 sparkplugg)it´s says: 1 225 R 1203 E
The block is light blue/ almost grey
The head is blue and the valve cover black .
I don´t know if the colour is a hint of the production year.
Best regards
Mrroth71
PostPosted: Tue Feb 19, 2013 10:53 am
Sounds like a later cast crank engine. (5 core plugs in the side)
See this article for more info:
http://www.slantsix.org/articles/dutra- ... blocks.htm
PostPosted: Sat Feb 23, 2013 8:41 am
Hi!
Yes, you are right, i have 5 core plugs.
but i still don´t know the year of the engine.
My guess is that the numbers 6 16 81 in the casting under the intake manifold means 16 june 1981, but it´s only a guess.
// Mrroth
 Post subject: More info!!!
PostPosted: Mon Feb 25, 2013 12:53 pm
More info on my engine:
5 core plugs
No spark plug tubes.
Hydralulic lifters!!
On top of the block ( nr 1 sparkplugg)it´s says: 1 (one) 225 R 1203 E
Mrroth
PostPosted: Mon Feb 25, 2013 1:43 pm
First reference
http://www.hotrodreference.com/8/chrysl ... g-numbers/
http://www.forabodiesonly.com/mopar/sho ... p?t=186070
Of course, yours is not there...
I found a thread with something similar...
http://www.slantsix.org/forum/viewtopic ... 471d7d3516
last generation with the forged crank?
/6 Dodge Charger 69
Users browsing this forum: morsim and 6 guests
