It is currently Thu May 07, 2026 3:57 am
PostPosted: Sun Feb 17, 2013 2:22 pm
My intake manifold had a plastic nipple that ran the brake booster on my truck. I somehow managed to break that nipple and need to find another one. does any one know where I can find that nipple? I am not sure I really want to try driving that truck without the brake booster working. Thank you for any help!
PostPosted: Sun Feb 17, 2013 3:01 pm
Was it connected to the #6 intake runner?
If so, I believe it's threaded as NPT (not sure of the size), and you should be able to go to the hardware store to get something that will work....
PostPosted: Sun Feb 17, 2013 4:24 pm
I think he wants th fitting that is on the booster.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Sun Feb 17, 2013 4:34 pm
6 Pack Dart
Check your local auto parts store.
Richard
PostPosted: Sun Feb 17, 2013 5:31 pm
I want the nipple that is on the #6 intake runner, it had at least one small branch off for a vacuum line for elsewhere on the engine. Unfortunately the auto parts stores don't seem to have it available
 Post subject: Junk yard...
PostPosted: Sun Feb 17, 2013 5:36 pm
That's a junkyard item, some of the late slants I've pulled out of trucks lately were NF threaded instead of NPT like the Pre-80's.
The good thing is that these are the same on similar era V-8's so find a 1980-1990 Dodge 318 and pull the tree from it...
