It is currently Fri May 15, 2026 2:02 pm
 Post subject: piston rings
PostPosted: Tue Feb 19, 2013 5:04 pm
is there that much difference in them? any recommended rings? im gonna pull my motor to put in a new clutch and to put a new cam in. while i have it on the engine stand im debating popping out the pistons and re ringing them. and honing the cylinders. also in the event that i do decide to pull the pistons would i need to change the bearings or would i be ok using the ones that are in there assuming they are still in good shape in the same cylinder?
 Post subject: If....
PostPosted: Tue Feb 19, 2013 7:31 pm
If the bearings and journals are still within spec of the owners manual and they aren't all gouged to crap from oil passage left overs then reuse them.
Rings are a different sort of animal, you might want to see how 'egged' the bores are if your engine has not been rebuilt yet.
Most likely a hone and ring job will be for standard rings, I normally use moly rings in my builds, but those are fresh bores and need a finer hone to finish after the overbore, not sure I'd recommend going that route on a hand rehone.
2 cents,
PostPosted: Tue Feb 19, 2013 7:44 pm
is there a way to check for the egging of the cylinder without the fancy tools?
PostPosted: Tue Feb 19, 2013 9:52 pm
Home hone job........cast iron rings.
My 360 munched up the #2 exhaust valve and spit it out the exhaust before I bought it. We hand honed the cylinders. Dropped in new pistons, iron rings. Over 150K on it. Never has burned oil. That cylinder was pitted. Head was destroyed.
PostPosted: Tue Feb 19, 2013 9:53 pm
You may be able to check with a new ring, and feeler gauges :shock: Just guessing!
PostPosted: Tue Feb 19, 2013 10:21 pm
Gday.
Do you own a set of vernier calipers?
If so you can get a set of "T" bore gauges for around $25.
they are a bit fiddly to use but with practice and patience you can get decent measurements with them.
Here is an interesting article on honing cylinders.
http://www.snowvalley.20m.com/bikes/dnthone.htm
Brendan.
1963 AP5 Valiant 225 PB 904 Stock except extractors & 2 1/4 inch exhaust.
1962 S series valiant 225 PB auto. factory every thing. Full restoration job.
Currently on hold till AP5 is on the road.
PostPosted: Tue Feb 19, 2013 10:23 pm
thats what i was thinking, feeler gauges or a flashlight. thanks for the info man
PostPosted: Tue Feb 19, 2013 10:27 pm
Gday.
Brendan.
no i dont have vernier calipers.
PostPosted: Wed Feb 20, 2013 5:34 am
Harbor Freight is your friend.
PostPosted: Wed Feb 20, 2013 3:54 pm
how would you use the vernier caliper to measure down into the cylinder?
PostPosted: Wed Feb 20, 2013 4:03 pm
6 Pack Dart
See post by slantsix above.
Richard
PostPosted: Wed Feb 20, 2013 5:55 pm
Richard
that offers information on not having to rehone the cylinders when not boring the motor. it doesnt offer any info on checking the roundness of the cylinders
 Post subject: Uhh...
PostPosted: Wed Feb 20, 2013 6:05 pm
With these two items you can measure the dimensions of the bores for egging.
When I purchased my hone and stones, I also purchased a dial bore gauge to make sure that I didn't "over do it"...
PostPosted: Wed Feb 20, 2013 7:09 pm
ok now it makes sense. given slantsik's article im not gonna hone the cylinder but i would like to make sure its not too out of round and needing a bore before i go through the trouble of putting new parts in it. im going to get the bore gauge and borrow a caliper off of a friend.
thanks for the help guys. im sure im gonna have more questions when the parts come in and the motor is torn down.
PostPosted: Thu Feb 21, 2013 3:13 am
http://www.slantsix.org/forum/viewtopic.php?t=51112
Have a read of this thread Before tearing that donk apart!
Brendan.
