It is currently Fri May 22, 2026 5:40 pm
PostPosted: Wed Feb 20, 2013 4:44 pm
Hello Slanters!I recently bought a 87 D-150 shortbed with of course a Slant6.It runs fairly well but has a,for the lack of a better word,skip while driving at 50 or any other steady speed.I did some adjusting and have a question about timing.The ESA is still in the fender and is hooked to full manifold vac.When I put a timing light on it I can set it at 16 degrees base as per the hood sticker but if I rev it I get no advance.Does it only advance under load or is the computer not operating? :?
PostPosted: Wed Feb 20, 2013 6:36 pm
Car Model: 87 B150, 1970 Valiant 4-door
Sounds like the ESA has had it and it's time to consider alternate ignition systems. (HEI is easiest option for a lean burn vehicle, and probably also the best.)
ESA, if working, advances timing with vacuum applied--period.
Users browsing this forum: Ahrefs [Bot], Google [Bot], Mike'68Dart and 6 guests
