It is currently Tue Nov 17, 2026 11:46 am
 Post subject: Differential Fluid
PostPosted: Fri Feb 22, 2013 12:15 pm
Possibly a dumb question, but all my search-fu yielded no relevant results. What is the recommended fluid to put in a 7.25" rear end? I will be "road racing," if it matters. You can basically read that as "I will be driving to work really hard through the city for hours at a time."
Also, recommendations for housing cover gaskets? Anything special out there? Mine shows signs of leaking.
I don't know my gear ratio, but it's likely high 2s-low 3s.
Escape Velocity Racing
 Post subject: What rear axle?
PostPosted: Fri Feb 22, 2013 1:05 pm
Depends on the axle type for gaskets (only a couple brands offered at all for the 7 1/4"), 8 1/4" and 8 3/4" are very available.
If you have a performance differential, follow the instructions on lube for the diff type (trac lock, ARB, etc...). I haven't had any problems using an over the counter gear oil with a stock mopar rear even with stock sure-grip.
PostPosted: Fri Feb 22, 2013 5:31 pm
RTV silicone gasket maker would be fine for a rear axle cover, if you can't find a gasket readily, 80-90 gear oil should be fine, 85-120 would be better in hot weather, if it's a posi make sure oil is compateable with a limited slip axle, most brands will say on the bottle
