It is currently Wed May 27, 2026 10:16 pm
PostPosted: Sat Feb 23, 2013 5:45 pm
Here is one of many problems with my Dart Leela. Everytime I go to make a turn, and I put on the turn signals the lights flash correctly but when the lights are on their brightest point the other lights dim, every light on the car dims when the turn signals get brighter. Voltage regulator? GFS on the wiring?
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
PostPosted: Sun Feb 24, 2013 10:15 am
Bump
PostPosted: Sun Feb 24, 2013 10:51 am
6 Pack Dart
Might be just bad contacts (corosion on contact points in wiring). :roll: :idea:
Richard
 Post subject: On later cars...
PostPosted: Sun Feb 24, 2013 5:15 pm
This can happen if you have a ground connection that is not 100% connected....look at the engine bay harness ground connections
especially. I also would start to suspect the steering column wiring/ connections. How old is your voltage regulator?
PostPosted: Sun Feb 24, 2013 5:40 pm
Voltage regulator is the one the factory put on. Has the tell tale dimple on the cover.
