It is currently Sat Jul 18, 2026 9:46 am
 Post subject: Tire Size
PostPosted: Wed Nov 19, 2003 10:07 am
I am currently running P225/60R14 tires on my 75 Dart. I have the stock Rallie wheels.
Can I go up to a 235/60R14 or a 245/60R14?
It would be nice to have some kind of a chart to go by to see exactly what size tires would fit.
Any help would be great thanks
PostPosted: Wed Nov 19, 2003 6:13 pm
I believe that you can go up to 245/60/14 on those wheels. If you have bigger wheels you can go to 255/60/15 and they fit in the wheel well.
Hope that helps..
Thanks
Hank
PostPosted: Thu Nov 20, 2003 9:42 pm
The 14" rallye is only 5 1/2" wide. 225x60 is really the biggest you should put on it. Largest recomended size is 215x60. A 245x60 tire should be on at least a 6 1/2" wide rim.
Cecil
PostPosted: Wed Nov 26, 2003 4:05 pm
Find your overall size of the wheelwell, then go here :
http://miata.net/garage/tirecalc.html[url]
It will show you the differance of what your running now to what you can fit underneath your car.[/url]
PostPosted: Wed Nov 26, 2003 4:06 pm
