It is currently Fri May 15, 2026 12:46 pm
 Post subject: EDIS install
PostPosted: Mon Dec 31, 2012 6:03 pm
Hi guys. The purpose of this was to let you guys see my current project on my duster. Right now I'm installing the EDIS system with megajolt. In the future I plan to use Megasquirt.
The following pictures are the install of the trigger wheel.
( Slant Six 73' Duster TBI )
 Post subject: VR sensor bracket
PostPosted: Wed Jan 02, 2013 3:32 pm
This bracket will hold the VR sensor. Used an L bracket and bent, cut and welded it with sleeves for bolts. Mocked this all on a spare motor.
Please excuse my welding
Just applied some coating because I'll be back at school.
 Post subject: Up and running
PostPosted: Mon Feb 25, 2013 10:30 am
Alright so I had a chance to come back down from school and wire things up. Put everything in their mocked up locations and it cranked right up =) . I didn't run it for long because of no radiator attached. Sorry no pictures I forgot. Next time I'll try running a proper advance map and take some pictures.
PostPosted: Tue Feb 26, 2013 8:07 am
Nice work. I think this belongs in in the EFI section - Mainly because Mega Jolt is an offshoot of the Megasquirt EFI controller.
I have wanted to do this upgrade for quite a while.. I have all the parts just not the time yet. :-(
PostPosted: Tue Feb 26, 2013 11:06 am
Whoops :P when I get everything correct I will make another post there.
Thanks!
