It is currently Mon May 18, 2026 11:12 am
 Post subject: crank problems
PostPosted: Sun Feb 24, 2013 9:12 pm
I'm building my first slant6 and putting it together with parts from all over and journel number three with the bearing with edges is about a 1/4 of an inch smaller than the journel in the crank now the block is a 1967 225 block and the crank is supposed to be forged so i'm pretty sure this is wrong and i need to be seconded thax john h
 Post subject: Yes...
PostPosted: Sun Feb 24, 2013 9:23 pm
Forged crank journal on the "thrust bearing" (with flanges), should fit, if it's about 1/4" short then you have a cast crank bearing and it needs to be changed...if you have a box of bearings and the factory (or warehouse monkeyboy) mixed one up, time to get it replaced by your parts house.
 Post subject: ok
PostPosted: Sun Feb 24, 2013 9:26 pm
if i put the bearing in that fits the crank it does not fit journel on the block side tight is that ok
PostPosted: Mon Feb 25, 2013 5:42 am
As suggested, it sounds like you might have the wrong bearing(s), a picture or better description of what isn't 'tight' might help. A proper bearing will have a slight interference fit in it's bore, what I call a 'snap fit' that is easily overcome by installing with just your fingers and once installed, it should not be loose.
A snip from a Dana/Clevite Tech sheet;
All bearings are an interference fit in their housing; this relates to something we call crush. Crush results from each half shell bearing being made a few thousandths more than a true half circle. When two bearing shells are placed together their outside diameter is slightly larger than the ID of the housing they fit into. When the housing cap is torqued the bearings are compressed, like a spring, resulting in a radial contact pressure between the bearings and the housing. Another way of looking at it is that the housing is squeezing inward on the bearings and the bearings are pushing back outward against the housing.
1966 Coronet Deluxe
PostPosted: Mon Feb 25, 2013 9:27 am
And more info "trickles-in"...
http://www.slantsix.org/forum/viewtopic.php?t=50932
Now I'm thinking that you may have a cast crank that you are trying to fit into a forged crank block.
PostPosted: Mon Feb 25, 2013 10:45 am
is the journel on a forged crank narrow or wide
PostPosted: Mon Feb 25, 2013 11:45 am
Forged crank = wide journal.
Cast crank = narrow journal.
PostPosted: Mon Feb 25, 2013 1:12 pm
/Users/JHouston/Documents/IMG_0501.JPG/Users/JHouston/Documents/IMG_0500.JPG/Users/JHouston/Documents/IMG_0499.JPG
PostPosted: Mon Feb 25, 2013 1:13 pm
block the narrow bearing fit tight in the journel and the wide bearing fits the crank good what can i do
PostPosted: Mon Feb 25, 2013 2:00 pm
Now it sounds like a cast crank block with a forged steel crank.
How many freeze plugs are in the block?
PostPosted: Mon Feb 25, 2013 2:17 pm
five down the drivers side
PostPosted: Mon Feb 25, 2013 3:03 pm
A 67 block should have 3 freeze plugs and a tapered rib behind the water pump, like shown below.
A cast crank block will have 5 freeze plugs and a thin rib, all the way across.
PostPosted: Tue Feb 26, 2013 4:57 pm
so i got a forged crank and a cast block what can i do
 Post subject: Get a cast crank...
PostPosted: Tue Feb 26, 2013 5:38 pm
Sounds like you need a cast crank from a 1977-1987 slant six.
