It is currently Fri May 15, 2026 4:29 am
Post new topic  Reply to topic  [ 35 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Feb 26, 2013 6:52 am
ILMopars, Have you checked this thread?
http://www.slantsix.org/forum/viewtopic ... te&start=0
Just pointing again how bad things can get in winter. Ted, how much of a MPG change you see in winter?
/6 Dodge Charger 69
PostPosted: Tue Feb 26, 2013 7:25 am
Up to 2.5 mpg. from the winter gas mix, longer warm ups, and a lot of short hops. My worst mileage this winter has been 22.5 mpg for local stop and go in the snow and ice. On longer commutes it has been running 24.2 to 24.5.
During the spring and summer it jumps back up to 25+ mpg.
PostPosted: Tue Feb 26, 2013 1:12 pm
Does anyone think it could be a thermostat issue. The car takes forever to warm up in the winter and was on the virge of overheating on the hwy. Has 19" core
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
PostPosted: Tue Feb 26, 2013 5:46 pm
As a reference:
My car starts to heat up in about two miles when it's in the low 40's. When it's in the low twenties it takes about 3 to 4 miles. That is with out having the fan blow over the engine. I run two electric fans and they rarely come on in the winter months. I also run a 180 Stat year round.
Sounds like you need to flush the block with the upper and lower radiator hose pulled. Why? So you don't plug up your radiator core....
Then separately flush the heater core reversing the direction every 2 minutes. Don't let it just dump on the ground, put a catch pan under it so you observe all the debris. A one way flush doesn't really loosen the crud. You need to go both ways at least 6 times. I do this every year and am shocked at all the odd stuff that comes loose and out of the system. It's like panning for gold....and I run antifreeze all year round!
PostPosted: Tue Feb 26, 2013 7:51 pm
That was one of the first things I did actually :)
Users browsing this forum: Google [Bot] and 11 guests
