It is currently Tue May 19, 2026 8:25 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page 1 2 3 Next
PostPosted: Wed Feb 27, 2013 2:52 pm
I picked up a good deal on a new 3.55 motive gear set from Jegs through their price match guarantee it took about 3 weeks but finally got here. this will be my first attempt at a gear change so if you have any pointers or useful information I would really appreciate it. pictures would be great....I read the directions and it seems the hardest thing will be setting the tolerances.
:idea: :roll:
74 Dart Swinger, supersixed.
PostPosted: Wed Feb 27, 2013 3:44 pm
http://www.jeepforum.com/forum/f11/gear ... -a-109859/
its for an 8.25 but its pretty much the same for the 7 1/4.
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
PostPosted: Wed Feb 27, 2013 3:51 pm
Thanks for the quick reply, draining the oil now so ill get to ready it.
PostPosted: Wed Feb 27, 2013 4:31 pm
Car Model: 1964 Dart 270
Can you post the part number from Jegs of the set you ordered I am going to rebuild my 7.25 sometime and am thinking of going with a different gear........Thanks
1964 Dodge Dart 270 four door. Three speed automatic 225 Slant with a Carter BBS carb.Image
PostPosted: Wed Feb 27, 2013 5:57 pm
Here's a pic with part number for the gear. It will show up around $269 but I used there price match and got it for $189 took three weeks to get here though not a stocked part. I will look for the link I sent them for the discount, and post it on here for you.
https://www.dropbox.com/s/e49m2ijwtsmym ... .45.28.jpg
PostPosted: Wed Feb 27, 2013 6:02 pm
Thanks sounds like you got a good deal...........
PostPosted: Wed Feb 27, 2013 6:11 pm
I'm stuck at this point, not sure how to slide the axels out?.
I don't see any other clips. What am I missing?
https://www.dropbox.com/s/tcvvis9yjn5a7 ... .23.03.jpg
PostPosted: Wed Feb 27, 2013 6:18 pm
Did you remove the bolts at the brakes that holds the axles in?
PostPosted: Wed Feb 27, 2013 6:45 pm
No....but got them out now.
:oops:
Thx.
PostPosted: Wed Feb 27, 2013 6:46 pm
I beleive you need to pull the pin that holds the spider gears in the case, pin is held in with 5/16 head bolt. After pin is out push axles into case C clips should fall out, then pull axles out
 Post subject: Lol...
PostPosted: Wed Feb 27, 2013 6:55 pm
I beleve you need to pull the pin that holds the spider gears in the case, pin is held in with 5/16 head bolt. After pin is out push axles into case C clips should fall out, then pull axles out
That's only on the 8 1/4" and 9 1/4" mopar rear axle, they are doing a 7 1/4" which is actually more like the 8 3/4" for axle retainage but does not have the drop out 3rd member...(in this case they have to remove the retainer at the axle ends to remove the axle).
PostPosted: Wed Feb 27, 2013 7:11 pm
Post plenty of pics if you can so I can look back at them when I do mine......
Never rebuilt a 7 1/4 was thinking it was like a 8 1/4
PostPosted: Wed Feb 27, 2013 7:19 pm
Took bolts out and Axels now slide out out now but still can't get gear out?.
https://www.dropbox.com/s/zvziwl7m8k5au ... .53.44.jpg
PostPosted: Wed Feb 27, 2013 7:24 pm
Fyi,
I was able to remove the pinion bolt by placing a pry bar for back up and using a good impact. Did not need the special tool.
https://www.dropbox.com/s/u6suq9s9fvjwg ... .23.18.jpg
