It is currently Wed Nov 18, 2026 1:11 am
 Post subject: Torque conv leak
PostPosted: Thu Feb 28, 2013 11:42 am
I heard that my torque convertor could be causing my front seal leak..is there a way to tell?
Love inline sixes
78 AMC Concord 258
PostPosted: Thu Feb 28, 2013 12:27 pm
Sure. Pull the trans and torque converter. Have the converter tested for leaks. You may be able to find a crack in the torque converter hub by visual inspection.
PostPosted: Thu Feb 28, 2013 1:10 pm
ok i pulled em and theres a groove around the convertor input shaft
Love inline sixes
78 AMC Concord 258
PostPosted: Thu Feb 28, 2013 1:19 pm
It sounds like the front pump bushing spun or it's worn-out.
Now is the time to pull the front pump for repairs.
Now is also the time to inspect all the friction and seals inside the trans. (rebuild)
The converter will also have to be repaired or replaced.
PostPosted: Thu Feb 28, 2013 1:56 pm
Can i just replace the bushing and get a new torque convertor?
Love inline sixes
78 AMC Concord 258
PostPosted: Fri Mar 01, 2013 1:59 pm
can i just get a new front pump
Love inline sixes
78 AMC Concord 258
PostPosted: Fri Mar 01, 2013 2:45 pm
Sure. Scroll down to the pumps section THIS page and match your year and lockup or non-lockup.
PostPosted: Fri Mar 01, 2013 2:59 pm
ok about how hard would it be to put one in?
Love inline sixes
78 AMC Concord 258
