It is currently Tue May 19, 2026 4:52 pm
 Post subject: crankshaft Question?
PostPosted: Fri Mar 01, 2013 12:24 pm
What does a crankshaft oil slinger look like? Also does my 6 cyl suppose to have one? And if so does it get installed between block and timing gear, Thanks again, Dana
PostPosted: Fri Mar 01, 2013 4:05 pm
6 Pack Dart
Some have others don't, it will go on after the crank sprocket.
It looks like a large thin washer with a keyway slot in the inner hole.
Richard
PostPosted: Fri Mar 01, 2013 4:12 pm
Thanks Richard
 Post subject: Yep...
PostPosted: Sun Mar 03, 2013 3:46 pm
I have found that the 60's slant sixes have mostly had these as a stock item, about the eraly 70's they seem to hit and miss, but mostly miss..
