It is currently Mon May 18, 2026 11:48 pm
 Post subject: Disk brake conversion
PostPosted: Sun Mar 10, 2013 4:22 pm
Will the front disk brakes from 1980 Dodge Diplomat fit a 1964 Plymouth Valiant?
PostPosted: Sun Mar 10, 2013 7:00 pm
Yes, but you will need 73-76 A-body upper control arms and lower balljoints. You can buy tubular UCAs from several sources (Reilly Motorsports and firmfeel.com best). You will use the Diplomat spindles, discs, calipers...
