It is currently Sat May 09, 2026 10:00 pm
 Post subject: Quick Time bell housing
PostPosted: Wed Mar 13, 2013 10:11 am
The catalog for this ( rm 7072 ) says you can use an 11 inch clutch. And it has the high starter location.
My interest is using this in a truck ( 4x4 ) and I want a stout clutch. It says it uses a 122 tooth flywheel, which seems to be the smaller one.
I thought you couldn't use the 11 in clutch with the smaller flywheel.
Can someone clue me in here?
I want to bolt an NV2500 to it (apparently, the bottom bolts match, the top ones are offset a little).
Can you really use a larger clutch with this bellhousing, than you can with the OD truck bellhousing?
'81 W150 on Propane... Oversize valves, Oregon Camshaft cam, 10:5 static CR, Distributorless ignition, megajolt timing controller, PowerTrax lockers.
PostPosted: Wed Mar 13, 2013 12:11 pm
The clutch information is wrong. Small flywheel only and therefore a small clutch.
PostPosted: Wed Mar 13, 2013 12:19 pm
Figures. Thanks.
I might as well just use a Junkyard aluminum housing, and have someone fill and redrill and tap it for an NV2500, then.
