It is currently Sun Jun 21, 2026 6:32 am
 Post subject: Jacking a Rear End
PostPosted: Tue Mar 19, 2013 2:39 pm
A couple weeks ago I called my father to ask him the proper way to jack up the rear end since it was my first time doing so. He told me not to put the jack on the differential but to instead on the axle housing close to the diff and place the stand as far from the diff as possible.
How do you guys jack up the rear end?
1978 4 door Dodge Aspen, Super Six
PostPosted: Tue Mar 19, 2013 4:18 pm
Under the pumpkin, under the leaf spring mount, on the frame box channel, from the bumper, under the front leaf spring mount...
 Post subject: What kind of jack?
PostPosted: Tue Mar 19, 2013 4:29 pm
If using the small 2 ton bottle jack or pump jack then under the axle tubes or shock plates would work best...If you are using a 3+ ton mechanics style jack put it under the differential and go for it....
The thing to be careful of is letting the jack down or the car shifting if the cup isn't placed right...
Good luck,
PostPosted: Tue Mar 19, 2013 7:17 pm
I used my 2.5 Ton floor jack on the axle housing near the diff when I changed the diff oil. I headed his words of caution but have been told that putting it on the diff is fine from anyone I've asked. My jack has a large cup with notches in the wall and that jazz. Good to know I can lift it just once, should save a little bit of time when I go under there to check my exhaust this weekend.
PostPosted: Wed Mar 20, 2013 7:16 am
Don't forget the jack stands
PostPosted: Wed Mar 20, 2013 11:41 am
I think that what your dad was saying is, to not put the jack out on the nose or body of the center section, but to put the jack under the center banjo,, which is good advice
that is a good place to lift, then put the jack stands under the axle tubes..
I wouldn't think about going under it with just the jack, it's from harbor freight...
PostPosted: Wed Mar 20, 2013 4:19 pm
I wonder if H.F. 's legendary quality control is creating a new generation of folks using jack stands?
I do buy and use their tools, but the only H.F. device I really depend on is the ANVIL!!
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
PostPosted: Wed Mar 20, 2013 6:35 pm
:idea: I would not trust the only body that I have with any jack,, if you are under the car, put it on stands
remember, the jack does not have to fail for you to get flattened. A jack picks up from one point, the balance could change and allow the vehicle to slide off the jack and fall. With two stands properly placed, the raised vehicle will be more stable.
PostPosted: Wed Mar 20, 2013 7:38 pm
Does your 78 Aspen have bumper jack slots? Could always look for one of those. I like my bumper jack. Still use jack stands for sure. Put a block behind any wheels that are still on the ground.
76 Dodge Aspen
225 Super Six w/ Dutra True Dual Exhaust
http://i1245.photobucket.com/albums/gg5 ... AG0095.jpg
http://www.youtube.com/user/BZuko1?feature=guide
PostPosted: Wed Mar 20, 2013 8:06 pm
Bumper Jacks are crap.(Hi-lift maybe?) Is there really anyone here that has been under a car without jackstands? Trusting a Jack? (I really don't want to know) :lol:
1964 Dart GT
PostPosted: Thu Mar 21, 2013 12:02 am
I would never get under a car with out it being on stands, even if I had some platinum coated $800 jack. I thought I should clear that up.
My Aspen has the bumper jack the car sold with but I honesty have no clue how it even works. I read about it in the owner's manual although i did not quite understand it.
PostPosted: Fri Mar 22, 2013 11:12 am
It works like crap. They were cheap stamped ratchet mechanisms that used the tire iron as the operating lever. There's nothing like feeling the car start to shift on gravel while it's on a bumper jack. Or "ka-chak, ka-chunk, ka-chak, ka-THUMP!" when the jack fails completely & drops the car. :o
63 Valiant Wagon
225 - 4 bbl
