It is currently Fri May 08, 2026 4:51 am
 Post subject: 65 3-speed manual fluid
PostPosted: Sun Mar 17, 2013 11:06 am
Hey. Long time since I've posted. The new baby took some time away from the Belvedere but now the engine is assembled and beautifully painted. Before bolting on the 3-speed manual, I want to put fresh fluid in it. I can't find what is required for it. An anyone know? Also, if a synthetic version is available, can I go with it?
 Post subject: Could use...
PostPosted: Sun Mar 17, 2013 11:17 am
3 speed manual is same as 4 speed manual:
Mopar used to use ATF in many of their manual trannies...but I would check to see what is in the gear box at the moment.
You may find oil in the box, in which case a nice 90wt GL-4 (not GL-5) will work fine. You can also use a non-detergent 30wt motor oil. Redline Manual tranny oil is also good...
Synthetics are not as good in this application as the synthetic is a bit 'slicker' than plain oil and can cause your synchros to not work as well causing a lot of missed shifts and grinding to get it into gear.
PostPosted: Sun Mar 17, 2013 11:50 am
Looks like oil. I would think that it would have a red tint to it if it were atf. Thanks for the help!
PostPosted: Thu Mar 21, 2013 10:24 am
I noticed today that in the Chysler service manual for my 69, they recommend Auto Fluid Transmission for the A903 (3 speed manual), but a manual trans gear oil for the 4 speed manual. I was going to ask if this was a mistake, but I guess is not, as from DusterIdiot answer...
/6 Dodge Charger 69
