It is currently Mon May 18, 2026 3:45 am
PostPosted: Sun Apr 07, 2013 7:19 pm
Thanks for all the info posted here! I relashed the valves on my engine, the second time I got it right, and the sucker now have a nice idle at low RPM (before that it could not idle below 1200 rpm without sputtering and dying when braking in idle).
Now, the question: my 1969 /6 is leaking some oil (126k, original), and I was looking for hotter plugs. I bought the NGK GR4, instead of the ZFR5N, and so far so good. Any opinion on these spark plugs?
/6 Dodge Charger 69
PostPosted: Sun Apr 07, 2013 11:41 pm
I have run the NGK UR4's for years (Peanut plug version). The 4's are hotter and work especially well in older higher mileage engines. You can see how my look by clicking on the red link below my name.
Glad you found nirvana with the valve lash. It does make a big difference and is very easy to do.... :D :D :D
Users browsing this forum: Google [Bot] and 7 guests
