It is currently Thu Nov 12, 2026 6:03 am
 Post subject: Flex plate fitment
PostPosted: Wed Apr 10, 2013 9:59 pm
Ran into a problem with a mid-70s engine, which had an early crank put into it. It wouldn't fit my '69 904. I'm getting a custom torque converter made so that everything should fit. My question is the flex plate. It's one for the later engine/trans, so I believe it's slightly larger than the one for the early motors.
Is this fine? I understand that if it was the other way around, it just wouldn't fit. But is a small gap between the crank and the flex plate ok?
69 Plymouth Valiant
 Post subject: I have...
PostPosted: Thu Apr 11, 2013 6:52 am
I think i have an early flex plate that I could let go for $5 = shipping if needed. I will check the morning.
PostPosted: Thu Apr 11, 2013 4:10 pm
Sure. This could be one of those things where the flexplate I have is fine, but I'm worried it will give me trouble after a few thousand miles.
69 Plymouth Valiant
 Post subject: Yes.
PostPosted: Thu Apr 11, 2013 4:45 pm
I have one pre-1968 "small hub" stock flex plate on my wall of 'spare stuff'.
Let me know if you do need it.
-rob
