It is currently Fri Jul 17, 2026 3:08 pm
Post new topic  Reply to topic  [ 49 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Wed Apr 10, 2013 9:47 am
Car Model: 64 Valiant
You can often get away with over-camming or over-carbing a 1200 lb car, but in a 2500 lb car, its a much different ballgame.
PostPosted: Wed Apr 10, 2013 11:16 am
well back in the day
I had a 4 speed/4;11 rear 1960 vette that I put a 1967 427/alumin intake with a a holly 3 barrel 950 cfm and mech secondarys if u did not have the r's abouve 1500 when u punched it would die........
3200 lbs curb weight aprox
slant six's RULE!
http://www.usajon.com
PostPosted: Wed Apr 10, 2013 1:18 pm
Exactly.
PostPosted: Wed Apr 10, 2013 1:27 pm
slant six's RULE!
PostPosted: Wed Apr 10, 2013 2:49 pm
Go for it! You will learn everything you need to know about overcarburation.
Then get a little AFB .
PostPosted: Wed Apr 10, 2013 4:20 pm
well maybe I'll run nitro...you need to remove the jets to run that.
slant six's RULE!
PostPosted: Thu Apr 11, 2013 6:37 am
Site Admin
Not exactly.
It's refreshing to see people trying things that others haven't been able to work out. The physical laws that govern fluid flow may very well have changed without us noticing. :D
CJ
 Post subject: Lol...
PostPosted: Thu Apr 11, 2013 7:00 am
Here's the part where James Doohan in a Red Shirt shows up and starts yelling "Y'cannot change the laws of physics No matter how much I try, Captain!!!!!!!" :lol:
PostPosted: Thu Apr 11, 2013 8:09 am
Not exactly.
CJ
this set up came off a good running truck
it was wrecked.
u have never run nitro have u.
Wikipedia :As an engine fuel
Nitromethane is used as a fuel in motor racing, particularly drag racing, as well as for rockets and radio-controlled models (such as cars, planes and helicopters) and is commonly referred to in this context as "nitro." The oxygen content of nitromethane enables it to burn with much less atmospheric oxygen.
4CH3NO2 + 3O2 → 4CO2 + 6H2O + 2N2
The amount of air required to burn 1 lb (0.45 kg) of gasoline is 14.7 pounds (6.7 kg), but only 1.7 lb (0.77 kg) of air is required for 1 lb of nitromethane. Since an engine's cylinder can only contain a limited amount of air on each stroke, 8.7 times more nitromethane than gasoline can be burned in one stroke. Nitromethane, however, has a lower energy density: Gasoline provides about 42–44 MJ/kg whereas nitromethane provides only 11.3 MJ/kg. This analysis indicates that nitromethane generates about 2.3 times the power of gasoline when combined with a given amount of oxygen
slant six's RULE!
PostPosted: Thu Apr 11, 2013 5:35 pm
Site Admin
I was talking about the air volume Jon. Not the nitro.
And no, I have not run Nitro. Your buttons are easy to push. :lol:
If it was running great, that's a testament to how the AFB, even if oversized, will tune on just about everything. What boosters are installed on it? What are the jets and metering rods? It's likely been running purely on the primary if the boosters weren't changed to make the primary smaller. The secondary butterflies are mechanical, the air door is not.
The secondary butterflies can be open as much as they want. If the air door doesn't open, then it's a big 2 bbl.
The metering rods go through the primary jets to vary mixture. The first step when dismantling one of these carburetors is to remove the metering rods so they aren't damaged when pulling the lid off.
CJ
 Post subject: Re: Lol...
PostPosted: Thu Apr 11, 2013 9:19 pm
On the other hand, I have meet people that believe that Jesus suspends the laws of thermal dynamics when pay day is a few days out and the gas tank is getting low.
PostPosted: Thu Apr 11, 2013 10:17 pm
Pull the jets out and load her up with nitro. I double dog dare ya. :lol:
PostPosted: Fri Apr 12, 2013 11:16 am
There are 2-3 guys running 750 AFB's on their race cars that are on this Forum quite a bit. A bit much for a street car.They seem to like them. Maybe they will chime in.
PostPosted: Fri Apr 12, 2013 12:42 pm
Jon needs to meet Putzy.....a member who ran Nitromethane in his street Aspen. He no longer posts......
PostPosted: Fri Apr 12, 2013 12:46 pm
You know, just as soon as I read Big D's reply, that just entered my mind...
an F-body with lots of piston melting fun.
:lol:
