It is currently Sat May 23, 2026 4:58 am
 Post subject: 225 vs 360
PostPosted: Wed Apr 17, 2013 12:47 pm
I have a 1974 d100 with a 225 in it and a 904 that I just spent 650 on. The motor has a serious oil leak and rod knocks. But its been getting low on power flatly and smoking really bad. I think it has blowby on the piston rings and I don't feel like rebuilding a motor right now. I have a 360 out of a 1983 grand wagoneer that was bolted to a 727 but the trans is 4x4. Does anyone know if the 904 will bolt to the 360
1974 dodge d100 slants six auto trans pow now bit soon to a better truck.
PostPosted: Wed Apr 17, 2013 1:04 pm
Slant six transmissions do not bolt to smallblocks.
However, for less than the cost of doing the conversion correctly you can rebuilt your slant.
PostPosted: Wed Apr 17, 2013 3:46 pm
That '83 Grand Wagoneer engine would be the AMC 360. That won't bolt into any Chrysler product. Might see if you can trade it for a good 225.
PostPosted: Wed Apr 17, 2013 3:57 pm
Try fixing the oil leaks and adjusting the valves on the slant six. You might be surprised.
PostPosted: Thu Apr 18, 2013 12:26 pm
How do you adjust the valves?
PostPosted: Thu Apr 18, 2013 1:32 pm
Hmmmm. First off, I recommend you get a factory service manual for your truck.
In the meantime, here is how you adjust your valves.
