It is currently Thu May 28, 2026 3:06 am
Post new topic  Reply to topic  [ 75 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Tue Feb 19, 2013 12:09 am
Car Model: 64 Valiant
Hi Mike, im up at the top end of Georgia on I-75 about 6 miles before you get to the Tennessee line. Parts testing would be great, im sure there will be plenty of items to go around to those that are ready to bolt them on and try them out. A timing cover is definately planned, and I will look at the water pump conversion also. Thanks for any help you can provide with input and/or testing.
PostPosted: Mon Apr 15, 2013 10:32 am
A little late to the topic though better late than never.
Edit: Shortened A LOT.
Timing cover as others have said. (maybe for chevy 235/261 as well, similar)
Remote Oil Filter Mounts? I have one already just figure maybe your own spin on it. (no pun intended)
Ram Hood Ornament? not that many of the car guys would want it though.
Rib belt setup
2BBL intake that fits the holley 2300 w/out adapter.
linkage/pcs to help with cable if 2300 is mounted parrallel to engine.
Plain alum intake plates, for those wanting to go custom alum intake on their own.
Lightweight Pulleys
Custom sparkplug wire holders, spec. to a slant.
custom oil/ trans pan with cooling fins built into them?
^^added capacity or preplumbed for turbo/ temp sensor
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
PostPosted: Tue Apr 16, 2013 9:43 am
Simple TBI adapter for those wanting to go FI and Ill vote for the Thermostat housing as well.
PostPosted: Tue Apr 16, 2013 10:40 am
If you are looking purely for a money-making proposition, you might want to consider something like the aluminum Thrush muffler tips sold in the 60s and 70s. Those go for hundreds of dollars whenever they pop up on eBay. Universal appeal and lots of potential buyers. Reproducing nostalgia items no longer available today would be a good way to make some money to support your slant habit!
 Post subject: But you could...
PostPosted: Tue Apr 16, 2013 1:17 pm
There are plenty of posts on how to make this conversion, especially if you have a manual tranny.
Is one way to do it, and the acc. cable is long enough and works both on shorty and long ram manifolds (and you can use the $12 throttle cable bracket found in the performance section at autozone if not into fabricating your own brackets- did this with an offy manifold in my other duster, so should work fine with the 2300 on a super six).
PostPosted: Tue Apr 16, 2013 10:15 pm
I have a list of Stovebolt stuff I already make as well as some new goodies to try out also. I like the 2bbl intake for the 2300 carbs with no adapters as well.
PostPosted: Tue Apr 16, 2013 11:12 pm
Fellow by the handle of PISHTA in the /6 forum on FABO just posted about drilling a head for F.I. bungs. I'm no machinist, but it looks kinda iffy, but a great idea!
Check this out:
http://www.forabodiesonly.com/mopar/sho ... p?t=227459
But how much better, not to mention lighter, in aluminum, hmmm?
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
PostPosted: Wed Apr 17, 2013 9:11 am
Yeah, there is pretty much the same thread here by him in the "Fuel Injection" section.
 Post subject: also late...
PostPosted: Wed Apr 17, 2013 4:51 pm
Im only 16, so I don't have the real world experience of the others, but how about an aluminum block with siamese bores? This would help with the extreme oversquareness... also provisions for more stroke, and the ability to accommodate the stock internals (exc for pistons would have to be bigger due to larger bore. Just some ideas to add to the pot :)
PostPosted: Thu May 23, 2013 10:28 am
Great!
I think that stuff like:
- Timing covers:
- Two piece timing cover
- Two piece timing Cover with belt drive gears with cam adjustment)
- Option for front-mounted distributor
- Driver-side Alternator mount (like in the early A-100 with Slants)
- Aluminum pulleys: Crank (single, double and triple), water pump, alternator
- Water neck
- a Two piece TALL valve cover plenty of room to use large valves and large springs
- Intakes: I can think of many options here!!!!
-Triple-Downdraught Webers (IDA or IDF) with injector booses so you can use the Weber-type injector bodies instead of carbs
- Mod-Man Intake: with large plenum that you can change to top of it and go from 2bbl to 4bbl, from Holley to Weber IDF, IDA
- Triple side draugth Webers (Clifford already make one)
- Cast Rockers in 1,5 1,6 ratios
I'm trying to tink away of what has already been done and its ready available.
And of course .... and Slant Six Aluminum head!!!!!!!!!!!! but with all the goodies in!!!!!!!!! LOL
Great to read this!!!
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
 Post subject: Already done...
PostPosted: Thu May 23, 2013 11:50 am
AREngineering already offered these and no one bought them so they are a bust...I still have the designs for these, but only racers are asking for them which limits the manufacturer's required bottom line.
PostPosted: Thu May 23, 2013 1:05 pm
I think the D/S alternator is the single nicest improvement that I made to my car. Race or street it just makes the passenger side a much more pleasurable place to work!
PostPosted: Thu May 23, 2013 6:06 pm
I have always wanted to move the alternator to the Driver side an down. It gives the engine bay a much cleaner look and you get a perfect access to all the spark plugs and maybe move th coil to were the alternator original place. That is just perfect for me, specially to work on the passenger side!!!!
Martin Zappettini
 Post subject: But...
PostPosted: Thu May 23, 2013 6:48 pm
move the coil to were the alternator original place
Just mount the coil bracket to the passenger side fender and get it away from the heat of the engine block, it will last longer (my family's been doing that mod for 40 years now,,,LOL).
 Post subject: another...
PostPosted: Sun May 26, 2013 7:32 pm
Finned oil pan that holds two more quarts of oil? Haven't ever seen one for the slant before...
